What are the most common reasons?
Eddie Rod
California
What are the most common reasons the 4x4 stops working in the second gen expeditions?
I have an 03 Eddie Bauer and 4x4 seems to not work.
I have changed out drive shaft u joints, front wheel hubs, tccm and still no luck. I can hear a "thump" when put into 4lo or 4hi which I assume to be the front wheel hubs engaging. A few days ago while in some sand I placed it into 4x4 and heard a "chain dragging" sound under the truck and had no spin in the front wheels. Any help any advice is greatly appreciated!!
Eddie Rod
Eddie Rod
California
Vacuum related problems. Check all your hoses, etc or get a smoke 'machine'
Thank you! That is actually my next move. I have some check engine codes related to a vaccume leak as well. Hoping that when they fix that they will find the root of my 4x4 not working.
Sent from my LM-V600 using Tapatalk
lbv150
Northeast
Chain dragging noise? That would be the transfer case and the chain inside let go....Time for a new transfer case.
