no one
Look like stereo plugs to me.
if you can give me an idea as to how many pins or wires and the colors I could look them up on the wiring diagrams however that will take some time to do and at this late hour It will have to wait till morning also better pics showing the pin layout would help
will do so thankx a bunch
i've got class till around noon but after that i'll go crawl under the dash and see if i can find them. Sometimes they use a generic harness with features that are not included on every model, so the plugs are just not used.
Anything not work in your truck? Light, radio display, odometer, etc.
take pics from diff angle...i cant tell what angle it is to get my bearing
when ford builds the expy they use wiring harnesses that will serve other functions and not all functions are used in different models XLT/EB
So it is very common to see connectors that aren't being use due to those systems not installed in your expy.
As I posted above the connector behind the kick panel may be for the air ride system and if your expy doesn't have air ride that connector would just be hanging unused
also check the color of the wires as there may be a second color on a wire and sometimes it is hard to see for example green with a blue stripe
maybe someone already posted this and i didn't see it but the first one looks like your trailer brake controller wiring connector....
