2018ExpyPlatinum
Good Lord!!!!!!!! 13 grand! That could go up too after they tear it apart. Good luck and hope it's done right. Glad you and your family are ok.....keep us in the loop.
Not surprising. Looks like front bumper, grill, light assembly, front quarter panel, and possibly hood. Not to mention and parts inside that were damaged including inner fender. Aluminum panels, so cost is higher and labor is higher. Then paint and because it is metallic it will be hard to match.Wow, I am simply floored that it cost over $13,000 to repair the damage indicated in the image in the original post (attached below).
Repair work looks good. Glad you're on the downhill side of the project! You may want to consider having clear bra installed on the new bumper before it gets chipped up. Prior repaired/repainted bumpers that I've had always seemed to get rock chips more easily than the factory paint. Normally they say at least 30 days to allow off gassing before clear bra would be installed on new paint.
My 2020 F350 had similar camera issues with the bed camera mounted in the 3rd brake light. It would work fine some days and other days when toggling through the camera views, it was fuzzy, blurry, or would just skip that view. Took the 3rd brake light apart and reseated all the connections and added dielectric grease to keep any water out and it's worked fine ever since. Maybe one of the connectors on your front camera just needs to be reseated. The o-ring gasket on my camera connector required a lot of effort to compress and get the connector to fully click into place, so I suspect it was never seated correctly from the factory.
It was “done” Friday. Went and checked it out and noticed the bumper cover wasn’t fully clipped on underneath the headlights. Get one side on and the other wanted to pop back off. Back apart to figure out what gives. Supposedly I should have it back today. There were a couple bumper parts that weren’t fully clipped together as well (around the tow hooks) so I assume whoever assembled it must have missing some small detail. Guess it’s gonna cost them! I kept saying to take their time, I’d rather have it “right” instead of fast. Said the same thing to my neighbor as his family owns the shop. I can’t see why it wouldn’t go back together perfectly either. No structural damage, and all parts are new OEM.
Hopefully today it’s back in my garage. Other than that everything looks good.
Make sure you make a devaluation claim and recoup some of that $13k
$14,000......whoocie ma'am. It just seems crazy what it costs today.
