intelisevil
I finally got around to installing the new rotors and pads on the front of my '03 Expy. I had searched and read posts and viewed videos so I was ready, I even bought a socket set with a 7mm allen socket because I knew I'd need it.
On the passenger side I removed the caliper first (7mm allen head bolts), then unbolted the bracket because that's what everyone said to do. Success, everything went back together just fine.
On to the driver's side. I thought I'd try something different, I removed the bracket and caliper as a unit planning to separate them afterwards. I'm glad I did . . . the caliper bolts are NOT 7mm. It looks like they might be 9mm? The socket set I bought has 8mm (too small) and 10mm (too big) but no 9mm! None of the sae's in the set felt correct either. Beyond this problem I made a positive discovery, you can replace your pads without removing the caliper bolts from the caliper bracket!!!!!
Plans for this weekend - Replace thermostat so the engine can finally warm up completely, rear pads and rotors, all 4 sway bar links, front sway bar bushings, rear Belltech 5550 1" sway bar, clean out the rain gutters, chop fire wood. So many projects, so little time before Winter . . .
