Why the heck is this hanging loose?
Qatarguy
Qatar
Hello all.
2011 Exp King Ranch.
Just seen this drop down from behind the dashboard (Passenger side), seems the previous owner tucked it behind and it got knocked down when i went over a pothole. Could anyone tell me what this cable is for? I'm not so electrically savvy....Hope i could get some clues here.20180305_130021.jpg
East-TN
Air Force
TN
It appears the 'sister/similar' plug is there in the picture...do you see any plugs missing a connector?
Qatarguy
Qatarguy
Qatar
@17LimitedExpy - No other cables hanging loose except this one. Everything else accounted for. Of course, going by its length, it may well have connected to anywhere, i did try to peep into the cavity around this area but couldnt spot any other loose end. I am hoping someone could identify the black box from where its coming out, to know more...
Plati
Could it have previously been plugged into that "sister connection" and was replaced in a repair ... which now drapes up & over the top, leaving the original one to hang down?
what is that in the center of the picture?
a splice to install replacement pigtail?
Temple, Georgia
Look closer at the pic where the wire comes out of the plenum box and held in place with a grommet. Ask yourself why a wire is coming out of the box....
bobmbx
Occams Razor would say its related to the HVAC system. But, Occam never had to work on a FOMOCO product.
bobmbx
Does everything work on the HVAC system? Is there anything that doesn't work correctly or at all?
Fordalways
North Central Texas
That was some pothole! if it disconnected a plug like that. It looks identical to the plug I can see part of in the right edge of the photo. And as previously noted, it comes through the grommet in the box making me think it is a sensor. Hopefully someone else with the same year can pop their glove box open and look to see what comes out of that grommet and where it goes. It doesn't seem to be mission critical now, but maybe come Summer when it really gets warm you might find something not working right with the A/C.
rjdelp7
2000 XLT
NY
Just a guess. Passenger side airbag, foot well lighting, glove box light. My 2000 XLT has wiring connectors, hanging near running boards. They are for models with the lighted running boards. The XLT did not have them, only the Eddie Bauer. The wire harness must be the same on both models.
Fordalways
North Central Texas
It is less expensive for the manufacturer to have one harness and the unused connectors are tied back out of the way. From what I can see in the photo, this looks like a connector coming out of the HVAC box and likely would plug into the harness somewhere. I guess we're all watching and waiting to see what is discovered.
