windshield washer light on
docraymund
philippines
Good day and happy new year to all! I would like to ask why my windshield washer warning light is always on but the reservoir is full? I also noticed that when you first start the engine the oil pressure gauge fluctuates from 0 to normal pressure but after it idles for a while the oil gauge is at normal level. I am wondering if my gauges are starting to go bad? It runs fine. ? My expy is a 2000 model 4.6 2WD. Thank you very much.
Bedrck47
Elizebethtown, PA
for the washer warning light it could be that the sensor has something blocking it. Try to get a hold of it and just turn it a little or tap on it.
You could have a clogged oil presser sensor The sensor doesn't read pressure it is more like a switch it is either on or off. Pull the sensor and clean it with some carb cleaner spray
