Wiring question
Ed Fogle
Oklahoma
2017 Expedition Limited with Heavy Duty towing package. My 12v slot doesn’t seem to be powered. The ground slot tests good but even with engine running voltmeter shows 0 between the 12v and ground slots. What can I do to trouble shoot? Where might a fuse be located?
99WhiteC5Coupe
I would check the harness connector for the trailer 4 or 7 pin connector, which is under the vehicle (I think on the driver side, above the spare tire) - to see if it is damaged and/or connected and/or corroded.
