Won't turn Over/start
Jacksonville Florida
My 2004 Expedition was stolen. The key cylinder was totally destroyed. I replaced the system from the key cylinder to the ignition switch from a salvage yard. When the key is turned on every thing appears to work however the starter won't engage and crank the motor,,, nothing happens when turned to the start position, the security light blinks rapidly. Does the new key have to be programmed to the car? If so how and who can do this!!!
Bedrck47
Elizebethtown, PA
(1) You may want to take a ORIGINAL key and place it near the PATS transmitter then using the new key see if the expy will start.
(2) You may need an un-programed key to try this with while having the original key near the PATS transmitter.
If the expy does start then you would be able to drive it to the dealership or to a locksmith otherwise if either has to make a house call you will pay more. Also you can figure about $100.00 to have two keys programed
Bedrck47
Elizebethtown, PA
being the expy was stolen. When you got it back was there any body damage? If so check the fuel pump cutoff switch even if there was no damage check it anyway.
Bedrck47
Elizebethtown, PA
It will reset the PCM
If your not getting fuel then check for voltage at the shutoff switch check input and output.
Check for fuel pressure at the fuel rail.
You could also try and spray some starting fluid into the throttle body to see if the engine fires up Just a little bit of starting fluid.
docraymund
philippines
How did it get stolen? They could not start the truck without the original key. Or maybe they just towed it? Did you check if any part is missing? Check the pcm.
Habbibie
Is it Christmas yet?
Chicago
Man it's so easy to steal a car chipped or not. If he has the right programmer with him he can bypass the chip and smash the teeth in the lock cylinder and use a blank key to start the car. All this can be done in under 60 seconds if you know what you're doing.
P
Towed it from the rear, broke out the key cylinder, wouldn't start so they abandoned it on a vacant property.
Only thing taken were some old CD's that can't be replaced, and a can of Silicon Lubricant which they sprayed over the interior and exterior to cover their prints.
Did the battery thing,, didn't work. Have to try the starter fluid. I don't hear the Fuel Pump running , reset it but nothing happened. Just turns over, won't start!!
Bedrck47
Elizebethtown, PA
Again check for voltage at the shutoff switch you need to be looking at the voltmeter while someone tries to start the expy You should see 12 volts and if the engine doesn't start the voltage will drop off. If your not getting 12 volts at the shut of switch let me know
Check out this thread Post #7 (Watch the video) and post #12 although his is a 03 the 04 is the same
http://www.expeditionforum.com/threads/2004-eddie-bauer-fuel-pump-driver-module.30227/
P
Still couldn't get it to start! Had a Diagnosis done with a OBDII,,, NO CODES or Problems reported. Says the Diagnoses Failed and can not be completed! Tech says, the ECM has been wiped clean but could not explain what that means!!!!! WHT???
Habbibie
Chicago
When you disconnected the battery you wiped out the ecu clean.
Understand this: a mechanical part fails gradually so that means it malfunctions slightly at first and gets worst over time until complete failure occurs.
An electronic part when it fails that's it it fails 100% the first time and only replacing it can repair it.
A fuel pump is a mechanical part. a fuel pump relay, the battery, the ecu are all electronical parts.
Go back to your first post, your answer is in that post.
This has happened to be on two different cars before... Both needed a new fuel pump.
