Here is a fix for your CD player if it stops working! I Tried it and it worked but stopped playing again about a month later! I just go thru the process again and everything works!
After starting the car and turning the car off, remove the radio fuses. there are 2 of them ( I believe they are #7 and #31 refer to your manual). Start your car for a second your radio won't come on cause the fuses are pulled, turn the car right off , put the fuses back in. Start the car. The radio will initialize, let it cycle thru, then it should work. Good luck!
