This is something I posted in a thread to help someone out. I think it could help a lot of folks who might not have read that specific thread.
I think most people that swear they have warped rotors, don't.
First one is from Power Stop:
It is hard to imagine the energy required to stop a vehicle traveling at 110 mph. Kinetic energy is ½ mass times the velocity squared KE = ½ mv2. Stopping a 2500 lb car requires 352,800 ft-lb of energy, the equivalent of dropping the car from an 11 story building. When you stop, almost all of this energy is converted into heat through the rotor in a very short time. Brake Rotors are designed to get hot, often in excess of 1400 degrees F. Contrary to popular belief, the temperature does not cause the rotors to warp, and this is not the reason why you get pulsating brakes. So what causes the brake pedal to pulse or feel like its vibrating?
The answer lies in understanding how friction works, and how high spots form on the rotor to cause the pulsating brakes. There are two primary mechanisms of friction at work during the stop: 1) adherent friction and 2) abrasive friction. For adherent friction, a thin layer of material is continuously transferred between the brake pad and the rotor. The breaking of the chemical bonds creates a resistant force to stop the vehicle. Abrasive friction is the mechanical wearing of the rotor and friction surface, like sand paper on wood. Brake pads use both mechanisms, but at higher temperature, adherent friction is what stops the car. The brake pad deposits material on the rotor, and as the pad gets hot, more material gets deposited. These deposits are caused by the resin (glue) in the pad. All brake pads use a binding resin that holds the friction component materials together. This resin turns to liquid as the pads get hot, and the resin material along with some other material in the pad gets deposited on the rotor. On overheated rotors, sometimes you can see the glazed resin material. It can look like someone brushed syrup on the rotor. The resin glazing forms a high spot on the rotor surface.
Another way to form a high spot on the rotor is if you clamp down on the brake after a hot stop. When the pad gets hot, it wants to transfer friction material to the rotor and it does not care if the rotor is stationary or rotating. If you are at a stand-still, the pad will imprint material on the rotor in the shape of the pad. The next time you brake, as the pad passes over the high spot, the temperature increases relative to the rest of the rotor. This causes more material to get deposited on this spot until it gets high enough to cause pulsating brakes. It does not take a lot of material to cause this brake judder, only .0007 inch is enough to start to feel the pulsation. PowerStop friction is engineered with lower resin content to maintain a uniform boundary layer of friction on the rotor. Another way to prevent glazing or non-uniform friction deposits, is to install drilled rotors. Drilled rotors help keep the pad cooler to prevent pad glazing.
Key Steps To Prevent Brake Pedal Pulsation:
Another site:
Surface Variation
The late Carroll Smith, a racing driver and engineer, wrote of what he learned about disc brakes while working on the original Ford GT40 race car in the 1960s when automotive disc brakes were still new. Smith noted that although a brake rotor can warp in many different ways, he never saw a properly assembled rotor warp in a way that causes brake pedal pulsation. He said that, whether on a race car or a street-driven grocery getter, the rotor irregularity that most commonly causes pedal pulsation results from uneven transfer of friction material from the pad to the rotor. To understand this, we need to understand two basic concepts about brakes.
First of all, brakes are designed to work within a specific temperature range and the pad friction material is designed with that range in mind. The friction material used for racing doesn’t work at all when the brakes are cold, and the materials that work best for noise reduction can be severely overheated when used on a race car.
Secondly, during normal use, friction material abrades from the brake pad and adheres to the rotor, forming an extremely thin layer of friction material on the rotor. When the pads and rotor are new, the bedding-in process establishes the initial layer. With continued use, the friction material is abraded away from the rotor and replaced with new material from the pad.
If the brakes are not properly bedded-in or if the pads are severely overheated at any time, the transfer of friction material from pad to rotor becomes uneven. Heavier deposits can be seen as stains or dark spots on the rotor that won’t wash off. Even if you can’t measure a thickness variation at these spots, they will have a different coefficient of friction when hot. Since that layer of material is only microns thick, it can be cut away by a brake lathe. If uneven deposits happen again, it’s time to select a brake pad that can handle higher temperatures.
- 5 moderate to aggressive stops from 40 mph down to 10 mph in rapid succession without letting the brakes cool and do not come to a complete stop. If you're forced to stop, either shift into neutral or give room in front so you can allow the vehicle to roll slightly while waiting for the light. The rotors will be very hot and holding down the brake pedal will allow the pad to create an imprint on the rotor. This is where the judder can originate from.
Then do 5 moderate stops from 35 mph to 5 mph in rapid succession without letting the brakes cool. You should expect to smell some resin as the brakes get hot.
After this is complete, drive around for as long as possible without excessively heating the brakes and without coming to a complete stop (Try for about 5 minutes at moderate speed). This is the cooling stage. It allows the heated resin in the brake pads to cool and cure.
After the brakes have cooled to standard operating temperature, you may use the brakes normally.
Another site:
Surface Variation
