Can you tell what these are
districk81
Willis
And how important they are... It's the shinny spot right next to the exhaust stud closest to the fire wall on the passenger side. The stud has Broke off and there's a spot like that oneither side of it were something is missing , it's just a big threaded hole there is some more but they're not missing . Im Thinkin the exhaust leak had something to do with them coming out? What are they and should I be worried & fix asap?
Sent from my SGH-T989 using Tapatalk 4
joecrotch
santa fe NM
If I am looking at this correctly it is where my exhaust heat shield is mounted to.
Yudaman
Southern Oregon
That's the access to change your muffler bearings... :joke:
From the pic, it kind of looks like a casting plug.
districk81
districk81
Willis
So do I need to,worry or not
joecrotch
santa fe NM
If it's just a casting plug no need to worry it's just a dimple left from the manufacturing process.
toms89
technical advisor
MD
On my 2000 expedition the passenger side tapped hole pictured is unused.
These heads have many applications other than the expedition, I would assume its just a potential accessory or bracket mounting point and would not be overly concerned. These heads also may be used on either bank assuming the cams have yet to be installed and on the drivers side it is one of two holes used to hold the power-steering reservoir.
The exhaust manifold stud is obviously broken which will cause exhaust leak but it looks to me like the other hole is just empty.
toms89
technical advisor
MD
I also see the word "SEX" just to the upper right of it but maybe that's just me ?! :facepalm:
sgtowing
Supporting Members
Valrico, Fl
It's not just you. I see it to. But then again, we both have dirty minds.
Sent from my SCH-I535 using Tapatalk 4
districk81
districk81
Willis
Ok well it's just all clean and everywhere else is dirty so I thought something fell off or something idk.so really I need to be more concerned with the broken stud. Looks like it's gonna be a pita
thegerb50
