Bedrck47
for a travel trailer I would recommend a good weight distribution hitch and sway control. You definitely will need a heavy duty tow package you may also want to increase the size of the transmission cooler if one is already installed or install one if there isn't a cooler on the expy.
my best advice would be to talk to a good RV dealer and see what they recommend
also check with your Ford dealer to see what it would cost to up-grade to the heavy duty package if needed but be cautious on what they tell you about towing weights
again check to see what hitch and connector are already on the expy and post that information on the forum
also update your signature as that will help for future information and responses
it can be updated in the USER CP section
