Bedrck47
things that you need to consider when towing
the weight of equipment and passengers in the expy does reduce the weight of the trailer you can tow keep everything within the combined weight limits.
when using a WD hitch you want both the expy and trailer to be as level as possible
maintain distance between the big rigs when they pass you getting caught in the suction that they can cause when they pass you can be a heart pounding and white knuckle experience. This is where using the manual control on the brake controller can be a benefit just tap the brake controller to help reduce sway while still maintaining your speed.
