Here is some more info. Can you play your music from your phone on your car entertainment system? If you are it is working.
Get help connecting your iPhone, iPad, or iPod touch with your car stereo
You can connect your iOS device with a compatible car stereo using Bluetooth, a USB cable, or CarPlay. If you can't pair or connect your iOS device with your car stereo, or you don't hear audio playback, learn what to do.
If you're using Bluetooth
- Check your car stereo's user manual for how to pair with a Bluetooth device.
- On your iOS device, swipe up to open Control Center, then taptwice to turn Bluetooth off and back on.
- Restart your iOS device.
- On your iOS device, unpair your car stereo. On your car's display, unpair your iOS device and any other devices. Restart your car and your iOS device, then pair and connect again.
- Update your iOS device.
- Install any firmware updates for your car stereo.
- If you still can't connect, contact Apple Support.
If you're using USB Playback
- Restart your iOS device and your car.
- Connect your iOS device to a different stereo USB port (if you have one).
- Try a different Lightning to USB cable.
Try playing audio from a different app. If you can't play audio from a third-party app, contact the app developer for help. If you can't play audio from an Apple app,
If you're using CarPlay
Many newer model cars support CarPlay—providing a safer way to use your iPhone in the car. To use CarPlay, you need an iPhone 5 or later with iOS 7.1 or later. Some features (like turn-by-turn navigation) aren't available in all regions. Learn more about
how to set up and use CarPlay.
If your car supports CarPlay over a wired solution, plug your iPhone into the USB port of your car. The USB port might be labeled with a CarPlay icon or a smartphone icon.
If your car supports wireless CarPlay, touch and hold the Voice Control button on your steering wheel to set up CarPlay. Or make sure that your car is in wireless or Bluetooth pairing mode. Then on your iPhone, go to Settings > General > CarPlay > Available Cars and select your car. See the owner's guide for your car for more information.
Information about products not manufactured by Apple, or independent websites not controlled or tested by Apple, is provided without recommendation or endorsement. Apple assumes no responsibility with regard to the selection, performance, or use of third-party websites or products. Apple makes no representations regarding third-party website accuracy or reliability. Risks are inherent in the use of the Internet.
Contact the vendor for additional information. Other company and product names may be trademarks of their respective owners.
Published Date: Dec 6, 2016
