Stalling when driving
dimension12
Minnesota
I ran two tanks of this crap in my 99 with a 5.4 auto EB edition. I think it added to my running troubles. I have cleaned the MAF, replaced a cracked exhaust manifold and upstream 02 sens. New coils and boots, PCV valve/hose assembly, and fuel filter.
When driving it feels like it has an intermitent ignition miss and when you give it enough throttle it clears up. Sometimes it shuts off like turning the key. It produces various codes. Evap, cylinder head overheat protection, lean bank 1, and anti theft system.
All of these are indivual codes and come after stalling. Lean code stopped after replacing 02 sensor.
Any ideas?
ChrisOIFdoc
Rio Rancho, NM
I don't know if the codes are secondary, but the symptoms seem like a failing Throttle Position Sensor.
docraymund
philippines
You need to check fuel pressure especially when those symptoms happen. And try replacing the fuel filter.
D
dimension12
Minnesota
It has a new fuel filter. The fuel pressure is within specs when driving. It didn't stall when fuel gauge was installed though.
The tps is responsive and seems within spec on my scanner when driving.
1997SCEBFEX
Northwest Panhandle
how many miles?
What other service items have you done?
plugs? egr? dpfe? vacuum leak test?
TPS is inexpensive and a relatively easy change out.
Any ideas?
What is, "two tanks of this crap"?
D
dimension12
Minnesota
Sorry. The crap is the E15 ethanol blend. Wasn't marked clearly in the pump and was 5 cents cheaper than regular unleaded. That's when stalling started.
Checked the plugs, no vacuum leaks found, put a vacuum pump on egr and it opens and closes as it should.
D
dimension12
Minnesota
Haven't tested the computer controls for the EGR system. Going to sweep TPS with volt meter when time allows.
Oh, miles are a little high @ 320,700.
rjdelp7
2000 XLT
NY
The E15 may have damaged something in fuel system or engine.
