Where do these missing vacuum lines go ??
scoot0073
scoot0073
Georgia
The line covered by plastic shroud is the vacuum line TO the hot water valve. The bare vacuum tube is the SUPPLY line TO the EATC vacuum manifold under the dash.
Thanks u so much. Yup I don't have the supply line coming out the firewall same place as the hot water vacuum line..
And I bet the dash would have to be pulled to find where it goes and run another line out..
Well I'm not pulling the dash so guess I'll just have to settle with just defrost... Grrrrr
Hamfisted
Ft Lauderdale
Well it all ends up at the electronic control manifold there at the front of the center console (under the dash area...). So you could pull the center console out and see if there's anything left of the supply vacuum line. Depending on what you find you might be able to use the hot water valve line to fish some guide string up through the dash grommet. You got nothin to lose at this point. Probably a lot of the original supply line is still there. Maybe even pull the firewall grommet out on the engine bay side and see if you can see the tube, get some needle nose on it and pull enough through to splice the pieces together with a piece of hose?
-Mike
scoot0073
scoot0073
Georgia
-Mike
Ok I'm willing to pull the center console . if I can get to the manifold then I can jus run all new line out .
I'll first pull that gourmet out and c if I can see any of the supply line and might get lucky enough to pull enough oout the gourmet to add to it..
Thank u for your time brother
Jared allen
L.r. ark
In the pic above where does the vaccum line go to that is causing my ac to switch from vent to frost so i was told
scoot0073
scoot0073
Georgia
Yes, it's my understanding that the vacuum line control's the actuator blend door in the dash to switch from defrost/vents. Which I don't have I only got defrost.
The other end goes to a black plastic square like hollow canister between the passenger fender and battery.
In my case I don't have the vacuum line coming through the firewall like the picture above so I would have to pull my dash to connect a new line and run it to the vacuum canister behind the battery.
rjtehan
