03 no crank...no clicking
jshreve
Charleston wv
Just drove it an shut it off for 20 mins...won't crank....everything lights up but no start...no clicks nothing.... help?
metaldrgn
somewhere
Is the security light blinking with the key in the run position?
Check for power at the F1.101 fuse and make sure the fuse is good.
Put it in neutral and try and start it. It could be your park/neutral switch. If that doesn't work pull your starter relay and check pin 86 to the negative battery terminal (or any ground) and verify 12v+ to make sure that part of the circuit is good. If that's good you could try swapping a like relay and seeing if it starts. If not check pin 85 to the positive terminal and have someone turn the key to the start position (try to start the car even though it won't because the relay is out) and check for 12v+. If you don't get the 12v+ something is preventing your PCM from closing the internal relay (i.e. a bad PCM or security system isn't cooperating).
J
jshreve
Charleston wv
Well I left it sit for about 2 hours an it started right up..haven't had a problem with it since
metaldrgn
somewhere
I'm glad it worked but I can only imagine you will be weary of it happening again. Could just be the key or lock cylinder not reading the key right. when it wouldn't start, did the security light flash on the instrument panel? If you have more than one key and this happens again, try the other one.
J
jshreve
Charleston wv
Did it again ..security. light does not flash ...I can also hear the relay click on the passenger side fuse panel....any ideas ...I rolled it forward an put it back n park and still no start even in neutral
ExpeditionAndy
Fort Wayne, Indiana
Lets start with the basics. What year is your truck?
In the mean time I remember reading something about this somewhere, let me do some research.
sharprd65
