I agree. A diesel is a much more robust engine. The heavy engine parts, must rotate much slower. The redline is around 3000 rpm. The slower RPM's starve the engine for air. Forced induction , is needed to compensate. Older Detroit's all had blowers. Gasoline fuel to air ratio, results in a hotter burn. Gas engines rev twice as high.I cannot begin to fathom the stupidity this post has. You have demonstrated you have absolutely know knowledge of engines let alone powerstroke. No gasoline engine turbo or not can come close. A diesel is a very low stress engine and btw they are still pushrod engines with four overhead valves per cylinder, a gasoline turbo engine isn't comparable in the least. The diesels have high pressure common rail fuel delivery, are low revving, have six head bolts per cylinder, no spark plugs. No comparison can be made.
