BuiltFordTough
Hey guys, Im new to the forum and starting my first thread. So thanks in advance for the help!
I just purchased a 2000 expedition eddie bauer with the 5.4 with a 196,000 miles. I have the auto climate control and luke warm/cool at best heat, both front and rear. This happens through all RPMs and the more you turn up the blower, obviously the cooler it gets. Being that I live in central Illinois, i will definitely be needing heat SOON. Im a little stumped though as Ive done several things to correct it and still seems to be no heat. Heres what Ive done and verified:
-Had the cooling system flushed and had both heater cores back flushed-good flow through the cores.
-Changed thermostat with a Motorcraft thermostat.
-Verified blend door operation and it is working properly.
-Engine coolant temp gauge is always reading perfect, in the middle or a tad less than middle. I have not hooked any type of scan tool up to it to read the actual engine temp.
-The heater hoses going into the heater core is hot, one coming out is warm.
Heres my question as I am trying to make sure I dont have a flow issue throughout the whole system as I am worried that all the hoses are not actually as hot as they should be. What temps are you all seeing (people with nice hot heat in the cabin) with an infrared thermometer at the following places?
-Upper radiator hose passenger side
-Hoses leading to and from the front heater core
-Hoses leading to and from the rear heater core measured under the hood
My biggest worry is that while the hoses are hot, I can grab any one of them and hold onto them for a few seconds without burning the hell out of my hand. Most vehicles you can barely even grab onto the hoses without having to let get go right away.
Sorry for the long post, but this is just getting annoying on my end and want to make sure I get to the bottom of this. Thank you all for any help you can give me!
