I went and tested mine in the driveway since it is taking a break from the road. Ambient temp is 66, inlet heater hose read 146, outlet read 136 (heater not running), upper rad hose was 146. Mediocre heat, engine up to temp according to gauge in dash.
When I did the heater core swap a year ago the heat would chase you out of the cabin for the first hour or two. Then it started the mediocre heat state it is in now.
On mine there is a complete new cooling system - radiator, t-stat, both hoses, heater core and water pump. The only thing that is still original is the hose/pipe from the water pump to the back of the block and scale that didn't come out with the flush.
I'll see if I can find a flow diagram of the cooling system and post it.
http://www.supermotors.net/getfile/167728/fullsize/coolant-flow.jpg
This is from the service manual for erratic heat:
Insufficient, erratic, or no heat
Low engine coolant level.
Engine overheating.
Plugged or partially plugged heater core.
Temperature blend door binding/stuck.
A/C electric blend door actuator.
Next time I'm able to check the temps, I'll see what the cylinder head is reading.
