Well, I have some news to report. Finished putting the truck back together last night, and it run good but the suggestion to do a compression test was a really good suggestion because it does appear that after all is said and done that there is an issue for sure regarding the piston / rings of cylinder #7. It still is markedly lower than the rest. I also saw when I had it apart that there is a chip out of the very top of it which tells me that that there was damage in there before.
As far as the smoke issue, it looks like there might have been two issues working together. one of them was that upon startup after it has been sitting for a while it would billow large amounts of white/off-white smoke for the first mile or two of driving. the other issue is that is would blow small amounts of blue/white smoke out after it was sitting at idle for a while, but it would not last long.
Now I know I need to drive it a bit more to see how the next few days work to know for sure, but after driving it home from the garage I did the work at and a test drive this morning it seems as though the start up smoke is doing much better, but the blue/white smoke after idle is still happening, but even that is a little bit better. This I think with my limited knowledge goes back to that bad cylinder #7
I do have a power train warranty on this which would not have covered the valve guide seals but it does cover the rings and pistons so now my plan is to drive for a couple of days to get an idea of how much oil it is consuming and then getting in touch with the folks at Auto Nation (where we just bought it 3 months ago) and see if they will honor the warranty.
Thanks for all the help, if there is anything else you can think of I would love to hear it.
