"Check Charging System" intermittently coming on
Temple, Georgia
I hope you used a fusible link when you "jumped" the old link. If not you don't have the protection of a link - the next weakest component will be your "fuse".
Glad you fixed your problem.
EliteFord
tulsa
Hi folks, i just picked up a multimeter and have about 12.7 at the battery after trickle charging all night. start the motor, then one side on the alternator and i get about 11.6, which i believe should be about 14.4. Belt is tight, and it appears to be spinning. Is my best bet a new alternator?
Bedrck47
Elizebethtown, PA
REPLACE THE ALTERNATOR
also thank you for replying to my questions that I asked in your other post about this problem It would have been helpful IF YOU DID ANSERED MY QUESTIONS
Wilson
Nevada
Ford Technical Service Bulletin 04-14-9 says:
DCT Code P0320 with possible drivability concerns and/or charging system warning indicator on with possible DTC P0620 -
Corrosion or damage to the 14305 harness or interaction of the PCM with the charging system.
*Reprogram PCB to latest calibration ($85)
*Replace 14305 harness (alternator to battery harness with fuseable link) ($57)
I replaced the alternator as well since I was only seeing 11 volts at the top of the battery and 11 volts at the top of the alternator.
I also replaced the battery in case there was a bad cell.
Everything runs fine.
