Expy for off-roading?
2007-2014 Expeditions all use the BorgWarner Torque on Demand (BW TOD) tranfer case system. ‘07-‘14 Expeditions TOD transfer case uses a specialized microprocessor (computer) in the transfer case that senses and can predict slippage before it occurs based on conditions monitored every millisecond in 4A mode. In 4A torque is variable and sent where needed via the cases brain. When you put it into 4H or 4L the transfer case computer locks it up 50/50 torque split front and rear with high or low range and no longer varies output. You have manually taken over its job and told it to lock everything up (needed in mud or rock crawling). This is good for severe conditions where slip can occur but on dry asphalt will result in binding of the driveline.
gtnator
CO
I've driven both the 1st Generation and the 3rd Generation trucks off road for work as a railroad trainmaster. I didn't own the trucks and they were considered emergency vehicles so I drove them wherever I needed to respond without too much consideration for their - er - well being.
I never got stuck with either truck in logging over 250,000 miles. I found the 1st Generation trucks much more nimble,responsive, a lot faster and more fun to drive off road. But both did the job wonderfully and other than flattening a dozen cheap government-bought tires, I never broke anything.
The only modifications on the trucks were Ford skid plates and the running boards removed.
Trainmaster, now that’s a cool job.
gtnator
CO
Amazing a junky ford product could do such cool stuff huh?
Again with the trolling??? You really are a piece of work. Dance for me
craig sargood
California
OMG, again with these 2 *******. Act like men and fight or shut the **** up. Never seen 2 men argue like girls before. I’ll gladly blast you 2 in the face to end this. Please be local.
Trainmaster
Old School Member
Rockaway Beach, NY
An old-school job for an old railroad and mechanical buff who doesn't mind long hours...
The Fords handled it well. First Generation trucks were inexpensive with the SSV Package and the 5.4... The 3rd Generations had the SSV package with the running boards removed so you could hop over railroad rails... Carried 600 lbs of steel crap in the backs. I still hear it clamoring in my sleep.
craig sargood
California
Not at all girls, just don’t like wastes of life as time, both your moms definitely should have swallowed.
