Mr Big
From Interstate Battery:
2. Charge the Battery Weekly by Driving The car For At Least 30 Minutes
When your car sits, the battery still powers all of the memory stored for the various computer systems. While this battery drain may not seem like a lot, it adds up over time and may drain your battery to where it may not crank the engine.
To keep your battery charged, you must drive the vehicle once a week for at least 30 minutes at a time at highway speeds to ensure the battery gets the boost it needs.
You may think that short trips to the store are enough to keep your battery from dying, but it requires a little more effort to keep your car battery healthy.
3. Connect a trickle charger to preserve your battery.
Many accessories in your car—like clocks, computers and security alarms—draw power from your battery when your car is off.
Suppose you plan to let your car sit for an extended period, like going on a long vacation. In that case, you can use a trickle charger to help preserve the life of your battery and avoid any headaches when you return. All you have to do is plug it into the wall to keep your battery primed and ready to go.
Consider getting a memory maintainer, so you don't completely wipe the memory.
4. Get A Portable Jump-Starter
A rechargeable jump-starter is another option that you can use to jump a dead battery without the hassle of involving another car.
Ensure you don't get stranded by a dead battery by disconnecting the security system, driving the car regularly or buying a jump-starter to keep in your car.
1. Turn Off the Security System to Save Your Battery
If your car has a security system and is parked in a secure garage, consider leaving the alarm off. If you do leave it on, it will only drain your battery faster. If you must park outside with the alarm on, drive the vehicle for at least 30 minutes at highway speeds every few days to refresh the battery with a little charge.2. Charge the Battery Weekly by Driving The car For At Least 30 Minutes
