jsawyer1181
I have a 1998 expedition 4x4 with the 5.4. This is gonna have a few questions so bear with me. First, the rear a.c. used to work and now if I turn the a.c. on even if the back is off I get a kinda squeak noise from the back where the core is but no cold air to the back. I checked the lines near the core (and the noise) and one line is cold the other isn't. I'm thinking the core of some sort. Any ideas?
Second part:
I'm sure this is the 4x4 shift motor but want to check. My 4x4 won't work anymore. It was working sporadically then the awd only worked, now nothing. Installed a new a switch and nothing. When I start the truck the lights come on like normal. Ideas?
Last:
The dreaded rear end whine. When I am accelerating it whines like a ****. Let off and it's quieter but still whines. Checked fluid and it's clean. I'm sure it's a bad bearing. Been doing this forever. Only major thing this truck does. So my question is, how hard are these to replace the entire rear end? Truck only has 127k on it.
Long time viewer of the forum so I figured you guys could prolly help me with this thing.
The only other thing I have to do is ball joints.
Second part:
Last:
