Heated and cooled seats
drokmofo
southern az
Just finished replacing the pigtail. It took me longer to get the plug off than it did to do all the connections. The ground pin @ M was welded and melted into the plug. I had to use some channel locks and screwdrivers to get the plug off after waaay to long and a few choice words. I tested the operation of the seats in both modes, both speeds and all is well. Very happy to have this creature comfort back. Especially with summer around the corner. Thanks mucho 20170308_200026.jpg to everyone who had input on this. It is a easy fix but sort of awkward on the body.
Gumbyalso
NC
Heated & cooled seats
After the fact I found this link navigator: heated seats lights come on for a few seconds and then goes that talks to the extra ground. My connector was smoked at Pin M and the DCSM showed corresponding burn damage. Since I took it to the dealer I don't know if the old DSCM would have worked with the new connector. I still would have ended up at the dealer to get it programmed, though for a lot less than the 2.5 hrs they charged for the repair. I paid $40 for the pigtail and $218 for the DSCM. Hopefully the added ground will prevent the same type failure. If I had it to do over I would have replaced the pigtail, tried it with the existing DSCM and if that failed, I would have gone on a junkyard search.
Since I wrote the above, the heating and cooling failed just on the driver's seat. I knew it wasn't the DSCM because I already went through that and knew that would affect both seats. The heat lights would stay on for 10-15 seconds and go out. Cooling would stay on longer, but eventually it would stop as well. I could hear the fan motor surging when I turned the cooling on. I decided to swap the "Cooling module" (the fan module, 9L1Z-14C724-C) between the passenger and driver's seats. The problem followed the driver's side "cooling module" to the passenger seat and now the driver's seat heating and cooling works. It's the same module on both sides. It's held in with just plastic hooks on my '11 EB. I unbolted the seats (takes a T55 torx plus) and tilted the seats forward to get access. Disconnect the cooling module electrical connector. Unhook the right side of the module first from the cushion spring by squeezing the cushion spring inboard, then slide the module to the left. Sliding it left will disengage the module from the seat vent and the hook that's on the left side of the module. I have the Ford shop manuals and there is nothing in there that describes this correctly. They want you to pull the seats and disassemble them to get at the cooling modules. No need. You can probably do this job in about 45 minutes, including vacuuming up all the french fries, m&ms, jolly ranchers, coins, and whatever else has landed where you couldn't get at them for the last seven years. The only tools you need are a T55 socket, a ratchet and maybe a torque wrench to put 30lb back on the seat bolts when you're done. Not only does the seat heat work, but it smells better without all that organic material under it. I will buy a new cooling module (@ $150) for the passenger seat when I get around to it.
KyleW
Vancouver
Awesome post! I had the same issue and used your advice to sort out that it was the blower. Since it was already toast pretty much I took it apart. It took a while since the screws are tiny and have a weird head on them. I just used some pliers to get the screws out. Then I used electric contact cleaner and sprayed it all over the copper fins which were VERY dirty. Then I let it dry and plugged it into the plug under the seat and sure enough it worked! Put everything back together and I have two heated seats again. Thanks for posting!
Matthew Jorgensen
Is it possible (within reason) to ADD heated/Cooled seats to a 2010 Expo that does NOT have them factory installed?
star-art
Pacific Northwest
It has never been done as far as I know. When I bought my 2009 XLT, I also got a complete set of seats from a 2010 Navigator with only about 6000 miles. I had hoped to swap them into my truck. Then, I discovered this mod requires some computer hacking to make it work. There's a Driver's Seat Module (DSM) that my truck didn't have, plus a Dual Climate Seat Module (DCSM) under the passenger seat. Both these modules have to be wired up and integrated into the vehicle network. Then, the buttons that control the seats have no physical connection with the DCSM. That is done via communication with the dual-zone HVAC module (something else my truck did not have).
If you really want them, and you are willing to spend some $$$, the company that makes the parts (Gentherm) offers aftermarket installs through authorized dealers. This will get you the same quality as factory OEM seats, but it is not cheap!
Trainmaster
Old School Member
Rockaway Beach, NY
Did you ever figure out the basics of the seat heating/cooling elements? Can you completely ditch the controllers and simply power them with your own switches? If that works, you can add your own simple adjustable thermostats. Or do the elements have fifteen 28ga wires coming out of them and that's wishful thinking?
star-art
Pacific Northwest
I understand them pretty well. They are not "elements" at all and are nothing like what you might be used to. The seats operate using "TED" units (Thermo-Electric Device). These produce heat in one direction when current is applied, and reverse operation when the current is reversed. This lets one unit provide both heating and cooling. They operate in conjunction with special seat foam that contains "channels" for air to flow, fans, and sensors. All this is computer controlled. The only way to install them in your vehicle is to use aftermarket control modules and switches. Unfortunately, the company that makes them won't sell parts to us. They sell only complete, installed systems through their authorized dealers.
Trainmaster
Old School Member
Rockaway Beach, NY
I know you were pretty involved with these, Star. What exactly does the control module do? Change voltage to the TEDs? Feed them varied AC frequencies? How are the TEDs powered? I would think you could mimic the output of these controls to power the elements and then worry about the variables. Since I know zero about these, am I being too simplistic? I'm sure you know what the TEDs want, so why wouldn't you just design another control that provides this?
star-art
Pacific Northwest
In theory, it seems simple enough. In practice, however, it's potentially way too complicated to bother with. It would be MUCH easier to just get some aftermarket control modules or try to get the whole setup from the manufacturer.
I don't know if the TED units need constant current or pulsed voltage. There are also sensors to make sure the system operates within safe limits. Given the fact these things are not unlike "heaters" they can potentially be dangerous if they were to malfunction.
The biggest problem, IMO, is even with a working factory setup the seat foam disintegrates over time, blocking the airflow and reducing the effectiveness of the cooling (it's not as big a problem with heating as the warmth radiates from the seat).
PaulMedik
