1955moose
- Joined
- Nov 23, 2014
- Posts
- 5,981
- Reaction score
- 1,338
The fact that you stated the hose going up to the heater core is cold, tells me your problem is a blockage before the core. Easy way to check water pump is pull lower hose crank over engine add water to radiator or expansion tank, water should surge out steadily. Be sure your hoses to heater core aren't reversed. The fact that it's not running warm, leads also to double check your blender doors at heater plenum. If you have a coolant air bubble, again it should affect proper running temp. Most readers here find a door not functioning or some sort of vacuum hose cut/ broke. Keep us posted. Moose.
