Suddently dont start hellpppp!!!!
Trainmaster
Old School Member
Rockaway Beach, NY
If your relays are melting the fuse box, your pump's drawing high amperage. Either the pump or the leads have to be replaced. Depending on the fuse box damage, you may be able to reshape the plastic with a Dremel and if you can get to the back, replace the terminal.
1955moose
Take hamfisted's advice, we've had too many members that buy replacement boxes that just don't work. The engine will run and have other problems, or don't run at all. As far as swapping another relay, I can do that on my 2000, but on 03, their soldered in. If your going to unsolder, resolder, I'd just put in a new Ford one. I bought a spare for mine, I think it was under $9.00 from Ford. You might have a loose or poorly tightened box in the pass kick panel, or are passengers kicking it too much. Pull it out do the resolder with new relay, should be fine .
Habbibie
Is it Christmas yet?
Chicago
If the Fuel pump relay is bad it can be replaced if you are able to solder a new relay in
If not then the best thing to do is replace the fuse box Be careful as the 03 expedition used two different fuse boxes AND you need to replace it with the EXACT part number.
If you suspect the relay is going bad there is a way to place a jumper and bypass the contacts See the attached link
See post #3 in this link
http://www.expeditionforum.com/threads/fuse-box-repair-vs-replace-its-time-unfortunately.35365/
Keep the forum posted on your results
OK Put your ear near the fuse box and listen so you may find out what is causing the buzz
May be a bad relay
Report back with your findings.
Can you read and understand wiring diagrams?
Do you have a Volt Meter?
Do you have a copy of the owners manual??
Check the connection contact points You may have to clean them up or tighten them together by bending them closer together. Let us know which relay is causing the problem
Your in PR by any chance did the expy get any water damage from the storms??
Ok Enjoy the beers
Man I miss this old fart, not many aggressive members left on this forum, most are oh so sensitive and quickly emotional.
W
wingrg
Puerto Rico
Jajaja thanks a lot guys could someone get the part number of the relay that have to be solder
W
wingrg
Puerto Rico
Anyone know if you can replace only the fuel pump relay or you have to replace all with the same type?
