TSB for replacing the blower control module?
Miekk
Madison Lake, MN
Do I really have to do do this TSB?
Per the dealer, I ordered part 9L3Z19E624B which is not the number in this TSB, but I thought I'd ask. Did they upgrade the part?
TSB
08-9-1
  • EATC BLOWER INTERMITTENTLY INOPERATIVE - STUCK ON HIGH/OFF
Publication Date: April 17, 2008
FORD:2007-2008 ExpeditionLINCOLN:2007-2008 Navigator
ISSUE:
Some 2007-2008 Expedition and Navigator vehicles equipped with Electronic Automatic Temperature Control (EATC) may exhibit a condition where the blower is inoperative no matter what speed or temp setting or the blower motor is stuck on high speed or off. Cycling the ignition may resume operation. The concern may also occur when using the electrical power point.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
  1. Open the glove box and remove Connector C297 from the Heater Blower Controller Module (HBCM).
  2. Remove the right front door scuff plate.
  3. Remove the right side kick panel to gain access to Ground G200.
  4. Cut black/white wire about 8" (20.3 cm) from C297. Strip the end 1/4" (6.3 mm).
  5. Obtain pigtail kit and using the approved splicing methods found in the Wiring Diagram (WD), Cell 5, crimp the butt connector and seal (with shrink tubing) the splice between the 13" (33 cm) pigtail and the black/white wire from C297.
  6. Disconnect the existing 14401 single ground eyelet from G200 and cut existing eyelet from the ground .
  7. Strip 1/4" (6.3 mm) insulation from the 14401 ground wire.
  8. Using the approved splicing methods found in the WD, Cell 5, crimp the butt connector and seal (with shrink tubing) the splice between the 3" (7.6 cm) pigtail and the 14401 wire.
  9. Attach the new interlocked ground eyelet to G200. Torque to 11 ± 1.6 lb-ft (15 ± 2.3 N-m )
  10. Install the right side kick panel and scuff plate.
  11. Replace the HBCM.
  12. Attach C297 to the HBCM.
  13. Close the glove box door.
PART NUMBERPART NAME7L1Z-14S411-ABEyelet Wiring Pigtail Kit7C3Z-19E624-CHeater Blower Controller Module
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATIONDESCRIPTIONTIME080901A2007-2008 Expedition/Navigator: Replace The HBCM, Includes Time To Isolate Ground (Do Not Use With 19700D8, 14200A)0.5 Hr.
DEALER CODING
That Heater blower control modual is the same as the electronic resistor.
sgtowing
Supporting Members
Valrico, Fl
Why not let them do it? They don't charge and you don't have to do the work.
Sent from my DROID BIONIC using Tapatalk 2
ptmares
Lakewood, CO
I thought if your car was out of the factory warranty, you have to pay out of pocket for a TSB repair? Not covered under warranty.
ptmares
Lakewood, CO
TSB
08-9-1
ISSUE:
ACTION:
SERVICE PROCEDURE
WARRANTY STATUS:
DEALER CODING
Stupid question, but here go's anyway. Does replacing just the resistor fix the problem, or do you have to perform the wire cuts and splices? Any idea what Ford wants to complete the TSB?
Miekk
Miekk
Madison Lake, MN
Update.
1) The old part number 7C3Z-19E624-C has been replaced by 9L3Z19E624B and no longer requires the rewiring TSB in previous posts.
2) $52 from Tousely Ford
3) TSB's are NEVER paid for by the dealer unless you are within your factory warranty, extended warranty that may have been added by Ford to the effected parts reguarding your particular situation or they are generous for whatever reason they deem fit.
Thank you.
ptmares
Lakewood, CO
Thank you.
Thanks for the confirmation on the TSB's. I thought I was getting hosed by my dealership.
Guess I am getting that part to avoid my a/c going out this summer.
AggieFCO
Have a 2007 EB and two to three times in the past had the HVAC change air direction (defrost for example to upper or lower vents) and velocity (from low to high) without any direction. Earlier today, my wife complained that the HVAC changed vent location and even temperature without any command. It seems as though having the system on AUTO has no effect on when this happens. Is this TSB supposed to fix the problem? Thanks.
AggieFCO
Wednesday morning bump. Anyone got any ideas if my issues are related to this TSB ? Thanks.
Miekk
Miekk
Madison Lake, MN
Based on reading through the actual provided TSB, I'd say no.
Where it blows is not probably not related to how fast it blows. The best way is to bring it to your dealer, get it diagnosed and get a quote to fix it.
AggieFCO
Thanks. The only problem we have is that the problem is so infrequent that it would be impossible for the dealership to diagnose. Guess I'll just have to wait for something more frequent...or hopefully the problem will go away.
ptmares
Lakewood, CO
Just replaced the Heater Blower Controller Module. Wish every part change was that easy. Now wait and see if it fixes the intermittent problem.
wadesdad
Eatc tsb
Wanted to take my wife's '10 Navigator to the "homeland" (Detroit, MI) for the '14 Autoshow, but her HVAC blower fan was intermittent. I did did my own version of the TSB with parts I had already -a red wire nut, black tape and a ring terminal to the wire and existing ground lug. I like to try the simplest solutions first. It worked great and was WAY cheaper than a new resistor. My thoughts were that the resistor was good because most of the time the fan worked as intended.
Discobee
Bellevue, WA
I just wanna say thank you for this thread...I had this issue, ordered a new part via Amazon.com for $70, and then replaced the part following the instructions here. Very simple, took me just under 15 minutes to do.
Barjrob1972
I just had the plugs changed and had the dealership do this TSB as well. My 07 EL was driving me nuts with the ETAC either turning off and then back on after a few seconds or sticking on high speed. I would have to kill the truck and restart to reset the system.
So far, so good.
rwmorrisonjr
Memphis, TN
Applicable for 2012?
Do I need to do the TSB for my 2012, or just replace the control module and be done with it?
Champdds
Tennessee
Thank you.
When I go to order the 9L3Z-19e624B that you mentioned is the replacement, I have advised on a we site that this is not compatible with my 2007 expedition el? Thoughts !
David
loelyf
Does this affect the rear air/blower at all? My rear blower has been intermittent for the last 2 years. Front cut out for the 1st time yesterday, but started working again a mile down the road.
Champdds
Tennessee
They are two independent systems I believe..
I purchased a replacement module for the front system from Pep Boys (Got a good deal with online ordering discount)...part fit perfectly, but a little different operation from the OEM it seems...1) There is a delay of about 2 seconds after starting the ignition for the fan to start, and 2) If I put the fan speed on the very highest setting, the fan will shut off after about 3 seconds...I have to hit OFF and then adjust the fan speed down one level and it works fine...I little odd glitch from the original, but livable
David
