3 JL 10"s and a 1000W amp
Expeditionary
Tampa, Florida
So a few months back I bought a 1000.1D Hifonics amp from SonicElectronix after I got my 3 JL audio 10W0s and the thing didnt work, it would power up and everything but put no power to the subs. Took it to 2 different shops and they couldnt find anything wrong with it, so being the procrastinator I am I stuck it in my room as a decoration and wrote it off as junk since I didnt want to pay for shipping to and from sonic electronix.
Long story short I have been running 3 10s off the stock sub amp and my Kenwood headunit. I didnt think it sounded bad but it didnt slam like 3 quality 10s should (OBVIOUSLY!) they are a high ohm sub (12ohm a piece) wired down to 4ohm in the enclosure, which is the only way I could see why the stock amp could even rattle my tailgate at full bass.
Last night I just had some random urge to plug the amp back into the truck and I turn on some tunes and the bass starts thumpin a little, go back play with the gains, boost knob all the way up, and WHAM! stupid bass.
No idea what was wrong with it but now it works and thats all I care about, now if I crank it up its a real head turner.
Will post pics but just thought I'd share with yall
Thermo
technical advisor
Expeditionary, kinda sounds like to me that you were not getting the signal back to the amp from the head unit. That or you had one of the switches for the amp in a mid position, which essentially opened the circuit inside the amp, leading to the lack of power output.
Expeditionary
Expeditionary
Tampa, Florida
yeah idk what it was last time i plugged it in but i messed with all the gains and turned it up all the way, checked RCAs for signal, the amp cut on, light up, etc. Just had no power to the speaker outputs... Works now, I want a CAP, volt meter, and I kinda want to port the box, but its a JL powerwedge specifically designed to hold 3 10" W0s. So idk about taking a saw to it.
Since ive got the tranny fixed, and the rest of my ball joints will be done tmrw, aligned monday, I think I'll be in the hunt for a 6" Suspension lift
Thermo
technical advisor
Expeditionary, skip the cap. If you are needing a cap, then you are skimping on the wiring and still hurting the power capability of the subs. If you can, get your hands on an analog multimeter and get a set of long leads. You want to connect 1 end (red lead) to the positive of your battery and the other lead (black lead) to the input of the amp. Now, crank up the stereo. With the multimeter set on the DC scale (2 VDC scale), watch the meter. If you see it jumping up over about 0.75 VDC (actually over 1.00 VDC in reality, but due to the response of the actual needle, you will see less), then your wiring is too small and you need to get some bigger wiring. I tend to shoot for under 0.5 VDC actual. Amazing what happens when you get an amp capable of outputting what it is rated at with the proper power in. I had lots of people thinking I was running around 1000 W in my car when I was only running a 300 W RMS total system.
Expeditionary
Expeditionary
Tampa, Florida
i have 4 gauge from the battery to the amp (The MAX input power cable size) and from the amp to the subs im running 16 gauge, which i need to upgrade to 10 or 8 sometime.
I think my wiring will be okay its a nice kit from DB Link, but idk driving around with it for the past few days it one of those things where it doesnt seem as loud as when I first plugged in, and now Im wanting more... like maybe 3 kicker comp 12s instead of 3 jl 10s, wire those down to 1.3 ohms or so in a custom ported box and really shake things up!
Thermo
technical advisor
ha ha ha ha. The stereo bug has bitten. Please keep in mind that if you are maxing out the amp right now, you are pulling about 100 amps just for the sub amp (at full volume). If you start adding in the other loads of the truck and you have not upgraded your alternator, you can very easily overload the alternator which will lead to lower volume, flashing headlights, and in the long term, a dead alternator. This is a slippery slope. If you need help making sure that your electrical system is capable of handling the power you are needing it to supply, let me know and I will help you out with this. You may not like the answer, but that is what will more than likely need to be done.
Newport News, VA
i upgraded my alt and it made my system bumb a lil harder...i have a ps1 18" in a ported box...with my current amp it blows my 2-kicker cvr's out the box...when i put my power acoustik amp on it...3600D...im in heaven...but i have to go back to my 12's because of family coming and need the room so the 3rd row has to be up
panda24619
San Diego
or just be like me and buy a lifetime warrenty on the alternator and get a new one every time they go out. not like they are hard to replace!
also sonice has a very good policy. should have called them up and they would have sent you the info for free return and they would have sent you a new one. i only shop there, never crutchfield.
rburch
Independence, Mo
I would recommend upgrading the alt! The 130 amp is just enough to run everything on the truck! 200 amp should do for now! lol!
panda24619
San Diego
my stock alt pushed everything just fine. all lights on and the sub bumping in the desert. then again i dont listen to it very loud cause i like to hear the truck working and listen for any weird sounds. but than again. i have a lifetime warranty on the alt. so when it goes out its takes me 45 mines to take it off go to the store change it and put the new one back in.
Expeditionary
Expeditionary
Tampa, Florida
I havent had any problems with the stock alt yet, I dont think the 1000w amp pulls 100amps because it has an 80 amp fuse on the back...
Anyway two of my friends have/had 2 15"s in their trucks, one has 2 Kicker L7 15s pushed by a 1500 watt MTX amp with a Kinetic battery in the back and an Interstate under the hood, 0/1 gauge wire from the battery on a stock amp. The other friend had 2 DB drive 15" subs powered by a 3000watt amp (idk the manufacturer) he had a Kinetic under the back seats, and a Yellow top under the hood on a stock alternator. also had a 650.4 kicker amp for the door speakers.
I havent noticed any loss of power since adding the amp like head lights dimming, batterygauge dipping when the bass hits, etc.
So ill probably keep the stocker till she blows then upgrade to a high amp one and a yellow top under the hood and put the Advance auto parts battery in the back of the truck lol
Thermo
technical advisor
Expeditionary, ah, so the 1000W rating is the peak then. So, you are really only pulling about 500W RMS. Peak power is meaningless in my opinion. It is only talked about since it is a bigger number and makes people think that you are packing more than you are. In that case, then the amp is only pulling about 50 amps. That is tolerable with the stock 130 amp alternator. You just may find yourself a little short in power on a cold, rainy night when you have the heat, wipers and a lot of other electrical stuff on and then cranking the stereo.
Newport News, VA
you wont have probs...i pushed 800 rms for the longest...upgraded to 200 amp cuz i knew i was going to be doing ahead...bigger system...more screens...lights
Expeditionary
Expeditionary
Tampa, Florida
its pushing an RMS of 475 to them because it is wired at 4ohms, the amp is rated at 1000wRMS @ 1ohm
theyre 12ohm subs wired down to 4ohms, my new plan is to just switch them out with some 4ohm 10s to have a 1.3ohm load on the amp so I can push ~900WRMS to them... just have to find some good 10s that will handle 300WRMS a piece, shouldnt be too hard
