AuctionExp
I could use some advise regarding a P0340 code. I have replaced the Camshaft Position Sensor, but the code came back right away.
Once the code is cleared ( I use my Garmin to clear it) the check engine light turns off, and remains off (until the vehicle is turned off and started again).
Could it be that the Camshaft Position Sensor is not the problem, and that something else ( I have read about alternators causing this) could be doing this?
Is it also odd that once I clear the CEL that it remains off for the entire trip ( 5 minutes or 1 hour). But once the Exp is turned off and started again, the CEL is back on. Maybe the computer only checks that circuit on startup?
Is there a way that I can test the plug for the Camshaft Position Sensor with my voltmeter to see if the problem is in the plug and not the sensor directly?
Anyone else have this issue?
*Update*
I have been searching online and found an article that talks about correct sensor synchronization, and that if the sensor is installed out of sync it can trigger the CEL. While I did find this article, I could not find specific installation instructions for the Camshaft Position sensor referencing a synchronization procedure. Ideas?
*Update*
