Hey all, I'm looking for input from anyone who's already done what I'm about to do. I just bought a used Vortech kit (which was missing some parts). It was a V-1 kit for a 97-03 5.4L, and they had upgraded the blower to a V-2 (quiet) blower. The blower looks like it's brand new off the shelf, looks awesome internally.
I already have an SCT tuner and a local shop to dyno and tune it after the install. I'm looking to add an air to air intercooler behind the grill, and also aiming for approx 9-10 psi. I ordered 39# injectors, they're not here yet. I'm planning on installing the inline fuel pump that came with the kit, but not the 8:1 FMU since I'm replacing the injectors and tuning it professionally.
Things I'm missing from the kit are the harmonic balancer, lower pulley (ordered), and the oil supply/return kits for the blower. I spoke to Vortech and they say I can use the stock balancer, it just has to be notched a little to fit the pulley. Their balancer is a stock Ford one that's been notched...and no longer available from Vortech.
I'm planning on trying to either keep the stock air filter housing which plugs into the fender for cold outside air- or at least make an inlet in the fender that gets outside air.
I've noticed on some of the newer installs that people are returning the oil into the valve cover instead of the oil sump. Looks a lot easier to install. Any reason I can't do that on the 2004 2V engine?
Since I'm wanting to NOT use the kit's FMU, should I not use the included inline fuel pump? Will the stock pump work ok with the 39 lb injectors?
I'm guessin that I should have approximately 350-400 hp and 450-500 torque when done. I'm not making a race car, or the "fastest" truck around, just playing around a little- so I'm not planning on going broke to extract every last HP out of it. The intercooler is very important to keeping it streetable and reliable, I can't believe Vortech thought it didn't need one.
BTW I need to update my signature pic, that truck was totaled, I have a red 04' 4WD now. I had a local shop do custom dual exhaust also, very cool looking- pics are needed to explain how they routed the pipes with the spare tire in the way....
Not good. May have been the underlying issue at my last track outing.
