Any Ideas?
TexasAngel34
Peyton, CO
Ok i have changed all i can to fix the problem and its still doing it now and then... I am thinking maybe its the main computer
The abs light
the gas to empty
air ride
reading of miles
all goes out together but when its gets low on gas it all comes back on , put gas in it then it goes out again..
We switched out the BCM , Check all connections in dash , fixed all wires to air ride system , replaced with new plug for the compressor..
I am out of ideas now, auto store said it could be the computer or the wiring harness to the computer... I am thinking computer
Anyone have any ideas please... Thanks guys..
toms89
technical advisor
MD
Is the air ride functioning ok?
Everything your describing sounds as if it could be an instrument cluster issue if it is strictly related to the indicator lights.
TexasAngel34
TexasAngel34
Peyton, CO
no the air ride goes in and out with all the other stuff... its very confusing...
TexasAngel34
TexasAngel34
Peyton, CO
i forgot to the mention, its only the back passenger side where the air ride acts up the rest stays up
toms89
technical advisor
MD
Sorry.... not familiar with the air ride and how it functions. You may need to school me on what it is or not doing.
One thought I had was possibly the instrument cluster may have been "tweaked" when and if the odometer fix was performed. But think this would only effect indicator lights and not the actual systems.
Another thought is the gem module as most systems are routed through it except for the engine and tranny.
toms89
technical advisor
MD
What are the odds all these systems run in a common harness leading back to the fuel tank. May be worth examining the harness leading back in that area for any signs of damage. Would check grounds back in that area as well.
cymru
NJ
The abs light is most likely the one on top of the pumpkin very common.
The air ride sucks get it switched out
The mileage cluster well that is common give it a good rap on the faceplate
The fuel sending unit is probably bad and that will give the gas gauge those weird fluctuations
Good luck
TexasAngel34
TexasAngel34
Peyton, CO
Hmmm thanks guys... gonna be going through everything and checking it one by one...thank goodness i have an extra vehicle
toms89
technical advisor
MD
Are you 100% certain all the systems mentioned indicate failure simultaneously? If not it could easily be actual problems with the individual systems rather than one central cause.
This previous thread you started was somewhat similar....
http://www.expeditionforum.com/f16/tons-issues-help-18980/
These were different systems but all could still have been attributed to the gem module. This would again point me to possiblities of gem/fuse block issues.
They were never addressed previously correct?
Its possible the gem/fuse block is intermittently getting moisture in it causing issues. Any heavy rain recently or possible sources of getting water into the vehicle?
cymru
NJ
Can you put on a diagnostic to see which ABS I am telling you it is the one on the pumpkin
The dashboard well who does not have that and the fuel sending unit is shot... classic description of that problem... let me know I want to see if I am smart or not
FordandPolaris
Saint Cloud, MN
We are here to help, not gauge intelligence...
Anyways, this might be hard to produce depending on where you live, but can you get the ABS to engage while the light is on? Use a dirt road or something maybe. My point is, if you can get it to engage while that light is on, then it is not in the ABS system, rather it is something electrical turning the light on and off. If you cannot get it to engage and the wheels lock up, that means the system is off, and then we need to narrow down why it is being turned off.
TexasAngel34
TexasAngel34
Peyton, CO
I live on a dirt road, it breaks loose when i want it to, but never really paid attention if the light was on or off.. I will try this today...ty for the info..
toms89
technical advisor
MD
The abs light
the gas to empty
air ride
reading of miles
Hello TA..
I am just trying to understand what your describing to be going on. From your post above I assumed you were getting an indicator light for the following.
ABS, Low Fuel, Air ride and odometer. And these all come on simultaneously but go out when you refuel. Is this correct??
If not please clarify. Give as much detail as you can. When it happens. Conditions leading up to. After large rain storm, 4 wheeling etc...
Honestly the odometer issue is so common I would consider it unrelated. The fact that you state that they all go out and come back on together is a key piece of information I keyed in on. So verification here is critical to at least my diagnosis. Multiple systems can fail at the same time due to water intrusion, 4 wheeling, corrosion etc... but the odds of them happening simultaneously are slim to none. If that's the case I believe there is some common factor and that's why I suggested gem module, short in the wiring harness, instrument cluster and grounds.
Canadian Expy
Toronto ON
I would think the GEM also, if replaced then the wires leading in and out of it should be checked, for shorting ..
Electrical stuff can be a Big PIA , good luck !
TexasAngel34
TexasAngel34
Peyton, CO
I will try to explain the best i can...
This has been going on for quite some time...it all started after i went mudding...
The 4x4 stopped working wouldnt switch over etc so i switched out the switch plug and the module on the transfer case, ok fixed that problem
Thats when everything else started... the abs light has been on for a while ... but then the gas to empty went out , the odometer stopped working , then i started to notice that the passenger rear was sitting low and my air ride compressor never kicked on.. we switched out the GEM , took my white face guages off thinkin it was shorting out...
Now a few weeks ago my radio started blinking on n off and then all of sudden it died and wouldnt hold a charge, found out my alternator was bad, replaced it, then low and behold everything stated above started working... air ride kicked on... gas to empty came on.. abs light came on ... all these yes all at once started working...
We have checked all the wires below and seem to be fine... i really dont know what else to do... first im told wiring harness going to computer may be bad, then main computer, fuel sending unit... gem module... so rightnow i am so confused as to where to start...
TexasAngel34
TexasAngel34
Peyton, CO
Yes as far as everything working after i refuel.. but didnt do it this time...my truck is possessed i tell ya and im about ready to drive it off a freaking cliff.... dont get me wrong it still runs great but all these issues at once are driving me insane..... grrrrrrrrrrrrrrrrrr
cymru
NJ
If you were referring to me about being rude I am sorry was not trying to be. And about judging my intelligence come on man you know I was joking. So again from what I have read I think the dashboard is unrelated like another poster. The ABS light you just mention has been on for awhile now. Again if you change the one on top of the pumpkin if you cannot put it on a diagnostic machine that is probably your issue with the ABS. So the real problem is the fuel gauge reading zero going to full when empty and whatever else you mentioned and I will say it again I really think it is the fuel sending unit.. Best of Luck
