Factory sub replaced
Ward
Dallas, TX
So I managed to replace my blown factory subwoofer yesterday, using info I've found here and around the web. It wasn't too bad of a job, I spent about 3 hours on it. The hardest part was getting the third row seat out, and getting the rear plastic loose enough to get the sub box out. Instead of cutting the "lump" off the back of the sub box, I heated it with a butane torch until it was pliable, pressed it down flat, and sealed the bolt hole with JB weld plastic epoxy putty. The sub I installed is an infinity reference 8" 4 ohm. I had to mount it clocked at 90 degrees so the stock wires would reach. I could have extended them to allow it to be rotated the right way, but it doesn't show behind the grille anyway. It sounds so much better than having no bass at all, and was well worth it!
Sub details: ProductWiki: Infinity REF850W - Car Subwoofers
RobertNol
Hernando, Fl
I actually think it looks good at a 90 degree angle like that. Is there a pretty decent sound difference between the two subs?
W
Ward
Dallas, TX
I'm not sure - the original sub was completely blown and not operational when I bought the truck a few weeks ago. I took out the stock sound deadener stuff, and I'm going to try replacing it with polyfill to see if I can get a little more sound out of it. Luckily, now that the sub is mounted from the front only, it's a quick job to remove it again.
W
Ward
Dallas, TX
Well, I went ahead and filled the box with polyfill. I used the cheap pillow stuffing available from Walmart. I think it definitely helped, the sub seems to respond better to lower frequencies now. I would recommend anyone else using this sub in the factory box to also use polyfill.
jbanks
McKinney, TX
I have not ordered the replacement subwoofer yet, but I pulled my factory subwoofer out today.
The foam surround was completely disintegrated. I thought about ordering a repair kit to replace the surround. But, I'm going to try a cheapo $19 subwoofer from amazon. Amazon.com: Pyramid PW877X 8-Inch 400-Watt Subwoofer: Car Electronics
It's crazy that so much had to be taken apart to get 1 bolt out. It didn't take too long. 20-30 minutes and went back together in 5 (I broke out the power tools for the bolts). I left the front cover off the factory sub when I put it back together, so I should be able to install the new one with no problem.
QbanCgar
Hagerstown, MD
that's a clean look Ward. i need to replace my sub as well as i'm hearing a rattlin' sound, although i think that could also be from the cover. i will have to take the cover off to reevaluated. i currently have my eyes on a pair of Kicker 10" subs in a box, but they will have to wait as i have a graduation party to pay for. i eventually want to replace my entire system, but again that takes $.. hopefully around tax i will be able to upgrade my system.
jbanks
McKinney, TX
Got my Pyramid PW877X 8-Inch 400-Watt Subwoofer installed. Sounds great and CHEAP TOO!
Oh yah...I glued a small thin piece of wood over the bolt hole and did not need to modify the LUMP in the back of the box. I found a bolt that I could thread into the hole to seal it off but that would have required me to modify the LUMP!
bcmaxx
trail,b.c.
Do all of these have a sub? ours has zero bass at all!!! its an eddie bauer
mpsjr
Baton Rouge, LA
If your EB is a Gen1 with the Mach Audio system, then it has a sub. If you have no bass at all (like I did when I got mine), then your sub is probably blown. Ford designed the system to turn the bass off to avoid damaging anything if the sub goes out. Replace the sub and you should be good to go. There are plenty of walk-throughs on this site if you need help.
bcmaxx
trail,b.c.
Well lastnight I took it all apart, I have 12 v power going into the amp, but no output to the speaker, so I'm going to guess it needs an amp?
mpsjr
Baton Rouge, LA
That's what I thought too. An easy way to test it is to grab a speaker, if you have one lying around, and hook it up to the output side of the amp to see if it will play. I had no power coming out of my amp until I hooked up the new sub. There's a built in safety shut-off for the amp to keep it from getting damaged if the sub blows. Even your door speakers will "limit" the mid/bass output until you install a new sub.
bcmaxx
trail,b.c.
Tried another just now, same , no output. how can I install a standard up in there? how would I figure oput the wiring?
mpsjr
Baton Rouge, LA
Did you try wiring the amp output to a new speaker? I had to cut the plug off of mine where it connected to the factory sub in order to hook up my new sub. Any 8" subwoofer will work, but you might have to modify the box.
I'm not sure if "a standard" means a speaker or another amp. If you're talking about hooking up a standard speaker, you'll just need to figure out which side is positive and which is negative.
If you're trying to install an aftermarket amp, you should try the search function. I've never done that, but I think several of the members here have.
GL
bcmaxx
trail,b.c.
GL
Yes I tried another sub speaker. But no luck. I have a small rockford amp that should fit . There seems to be a lack oc rca s . And I read the signal wire is only 5v and I need 12v
jbanks
McKinney, TX
Look at the Mach wiring diagram on this page: Ford Explorer Ranger Enthusiasts "Serious Explorations"® - View Single Post - Subwoofer plug question
What year Expy do you have?
I'm wondering where you read the 5V from there should be a 12v power supply wire and then you will have the Subwoofer+ and Subwoofer- (Red/black and brown/orange wires), these will be lower voltage. I'm not sure what the "High Audio Mute" wire is. I would test it and see of that is the switched power(turn the amp on and off) wire. If it is only a 5v turn of/off you would wire a relay in to provide your am 12v to turn it on.
bcmaxx
trail,b.c.
awesome! thanks for the link to the pdf schematics! okay another one, I/m sort of an idiot but do I just kook the + and - to my aftermarket amp for the input? I've only ever used rca wires.
Tacoma WA
1997 ford expedition EB
ok I just got an awesome JBL 8 INCH SUB REPLACEMENT / hooked it up with a speaker wire before taking all apart just to see if amp would work but NOTHING, NO SOUND not even a crackle....if I were to pull that panel off is there something Im missing here...I also checked the fuse/relay under hood which is where our sub amp fuse/relay is located. why cant I get sound guys??
I am going to remove the outer panel here in a bit but I do not think there is a reset botton or anything that lucky lol...
if amp is blown can someone recommend an AMP that will work or like I asked in this post already what am i missing here....again what I did was to use the two wires that went to the original sub added a foot length of heavy gauge speaker wire to new sub then turn on system with key on and nothing at all...ok please get back to me....also if the amp is bad should i run wires from battery to new amp or what? thank you for a quick response please
Michael
