superexpy
I got to spend 2700 on a new trany. I guess the trany did pretty well for being supercharged for 10 years......
I've got a rust hole in the center of the truck on both rockers/right between the front and rear doors, right above the running boards. Its the only rust on my truck. They sell those replacement rocker panels on Ebay, do you cut out the whole rocker and replace it? or just the hole and cover it?
Took mine to the stealership and had the transmission serviced, system flushed, all fluid changed to Mercon V, she seems very smooth now, I think I was having a bit of torque converter shudder which I do not feel at all any more. 131,000 miles and no idea of previous maintenance performed and I tow, they said the trans. had definitely been serviced in the past and it and entire vehicle is in very good condition for age/mileage.
I accidentally completely locked my drivers side door shut from inside and out today... I was working on the window regulator when I thought I would tape that pesky bar down that is supposed to be connected to the exterior key lock on the handle (been broken for years and rattles around in the door). Put the panel back on and get everything back together, close the door to see if the rattle is gone, and it will not open back up. Go around the other side and press the unlock button, lock still doesn't come up. Pull on the interior handle, door won't budge...
I managed to get a pliers on the lock tab and pull it upwards peeling some of the tape on the inside off. Lock now functions again, but I felt pretty dumb at first having engaged the lock like that haha.
Oh and I got my window fixed. Duct tape is the answer to all problems.
got rearended and people ask why i leave the hitch in lol
replaced a headlight
Today.... I used my Expedition for the coolest thing EVER! I drove my daughter home in it!
I take it no damage.
