Supercharger
reefkrazy
ct
Hey,
Is this a good deal for a 5.4l supercharger? Is there anything I should look for? Also Can I bolt this right on my 5.4l or do I need to change or do? Thanks!
Ford Supercharger for 5.4 L with upgrade pulley (2.8)
Asking $ 275.00
toms89
technical advisor
MD
It's only a very small part of the puzzle.
You need lightning lower intake, plenum, injectors, mass air sensor, fuel pump, alternator, pulley bridge, lower crank pulley, heat exchanger, reservior, intercooler pump, tune, etc......
reefkrazy
reefkrazy
ct
Ahh. So its not so simple as bolt on a super charger on top of intake. Thanks for the info.
gunnergrant
Arizona
Not to be rude but if you didn't know what youve been told already about extra parts, you have a LONG way to go before doing a job like this. Especially on an expedition.
SOLISIMO
Ft. Lauderdale
+1 look at another 2k on top of that at the most
reefkrazy
reefkrazy
ct
Very true, Though I don't know what it takes to do this, this is Why I ask. And to say I cannot do the work is crazy because you don't know what I am capable of ! But thank you for the info That helps and thanks for your opinion .
Static54
Milwaukee WI /Anthem, AZ / Grand Rapids, MI
I didn't know anything before I booster my 05 silverado. Just gotta research and get the parts and have the time and downtime to do this stuff. I went from knowing basics to re doing my rear end / front end gears / transmission / turbo / exahaust. But like they said all the parts add up.
