Removing Courtesy (door) Lights
B
bedrck46
i'm assuming they don't offer the dome lights (PC579...in between driver & passenger side) in an LED bulb? i guess one would have to cut & then rewire some LEDs themselves?
those dome lights have two types of lamp holders one you have to wire in and the other type you just insert a lamp like on the door panels You can find the lamp holders on e-bay or find them in some fords or GM's in a junk yard I did them in what you did in green I did in blue I also got some 18 inch led strip lights and mounted under the dash in order to light the floor am planning to do the same for the 2nd row seats
I'll see if I can post a pic to give you an idea.
QbanCgar
QbanCgar
Hagerstown, MD
cool, i'll check on ebay to see if i can find the ones you're talking about. the ones i have in now are the bulb insert that you screw in. i figured i would have to do a small modification to get the LED effect in my Dome light.
B
bedrck46
if you have the ones that you insert a bulb into and then just re-inset the lamp holder with a slight twist then you can use the same size led bulb that you used in the door panel the base on the 579 is about the same on the 94 bulb
B
bedrck46
Pics attached also the strip lights are 12 inches not 18 inches
QbanCgar
QbanCgar
Hagerstown, MD
are you referring to these lamp holders
QbanCgar
QbanCgar
Hagerstown, MD
i think i found the ones i need to get. i seen these a few times while i looked on here, but never REALLY paid any attention to the detail of installing the lights w/ that adapters.
B
bedrck46
none of those but the first set are close What I am referring to does not have the wires attached
Go to e-bay and paste the following in search
6pcs GM 1/2 Hole Twist In Instrument Panel Dash Light Bulb Socket 194 168 Wedge
B
bedrck46
Ultra Blue 1.72" 42mm 4-SMD-5050 211-2 578 LED Bulbs For Car Interior Lights
2 PC Xenon 578 211-2 212-2 FESTOON SUPER BLUE DOME MAP LIGHT 4-SMD LED BULBS
Got those off of e-bay They have them in green also
QbanCgar
QbanCgar
Hagerstown, MD
yeah i have the festoons in my rear & sides (rear passenger/driver's side), but my dome are the twist bulbs (PC579s). i will order a set of these & see if the twist in socket work.
B
bedrck46
My 99 had the twist in sockets but my friends didn't but we intend to get some from the u-pick -It yard They are also on a lot of GM vehicles My 2001 also didn't have the twist in type that you could just insert a bulb into But it does now
QbanCgar
QbanCgar
Hagerstown, MD
now let me ask you this. w/ these do you just remove the PC597 bulb, insert the 1/2 hole socket & the connect your LED 194 & BAM!!! or is there some other minor modification that needs to be done? & if i'm correct, the glove compartment bulb is a 194 as well?
B
bedrck46
correct in the overhead lights I haven't changed my glove box light yet but should just be a simple remove and replace
QbanCgar
QbanCgar
Hagerstown, MD
just ordered the 1/2 hole sockets & 5 194 LED bulbs to replace the dome, glove & license bulbs.
QbanCgar
QbanCgar
Hagerstown, MD
just got my sockets & LED bulbs today. hope to install 'em whenever i get off work today. will post pics once completed. now my license plates bulbs, will have to wait 'til the snow has stopped.
B
bedrck46
which color blubs are you using for the license plate for what I have been told any color but white isn't legal in PA but your in MD
QbanCgar
QbanCgar
Hagerstown, MD
oh i'm using white. no need to give 'em a reason to pull you over. also using the same for the glove compartment. i'm actually thinking of swapping out the LEDs that i installed in the 2nd row & rear cargo area for green LEDs. my 2 year old will get a kick out of them.
QbanCgar
QbanCgar
Hagerstown, MD
well, i put 'em (dome lights) in yesterday & i realized 2 things...1) i didn't need the 1/2 GM sockets b/c i i don't know what i was thinking, i just the existing sockets i had in there. & 2), i am going to need the longer 194 bulbs. i ordered the flush mount 194s & noticed they aren't as bright as i thought they would be. nonethelss i'm content w/ the look.
