Removing Courtesy (door) Lights
B
bedrck46
Guest
My 99 had the twist in sockets but my friends didn't but we intend to get some from the u-pick -It yard They are also on a lot of GM vehicles My 2001 also didn't have the twist in type that you could just insert a bulb into But it does now
QbanCgar
QbanCgar
Hagerstown, MD
now let me ask you this. w/ these do you just remove the PC597 bulb, insert the 1/2 hole socket & the connect your LED 194 & BAM!!! or is there some other minor modification that needs to be done? & if i'm correct, the glove compartment bulb is a 194 as well?
B
bedrck46
Guest
correct in the overhead lights I haven't changed my glove box light yet but should just be a simple remove and replace
QbanCgar
QbanCgar
Hagerstown, MD
just ordered the 1/2 hole sockets & 5 194 LED bulbs to replace the dome, glove & license bulbs.
QbanCgar
QbanCgar
Hagerstown, MD
just got my sockets & LED bulbs today. hope to install 'em whenever i get off work today. will post pics once completed. now my license plates bulbs, will have to wait 'til the snow has stopped.
B
bedrck46
Guest
which color blubs are you using for the license plate for what I have been told any color but white isn't legal in PA but your in MD
QbanCgar
QbanCgar
Hagerstown, MD
oh i'm using white. no need to give 'em a reason to pull you over. also using the same for the glove compartment. i'm actually thinking of swapping out the LEDs that i installed in the 2nd row & rear cargo area for green LEDs. my 2 year old will get a kick out of them.
QbanCgar
QbanCgar
Hagerstown, MD
well, i put 'em (dome lights) in yesterday & i realized 2 things...1) i didn't need the 1/2 GM sockets b/c i i don't know what i was thinking, i just the existing sockets i had in there. & 2), i am going to need the longer 194 bulbs. i ordered the flush mount 194s & noticed they aren't as bright as i thought they would be. nonethelss i'm content w/ the look.
edyk1986
