2005 ford expedition 5.3l 3v CEL p0430
2005Expedition
Jackson
Car run and drive perfectly smooth, gas miles is normal, I dint note any kind of performing lost, I just add a bottle of fuel injector cleaner ( chevron ) couple day ago, CEL on today and it show up 4 code, all was P0430 . Any idea ?
65comet
Porter, IN
The code is for a EGR valve problem. Most commonly there is a vacuum line tee coming off the passenger side valve cover and connecting to the EGR valve. It is notorious for crumbling and breaking apart. I'd check those vacuum lines first.
B
bedrck46
The following was copied from the 2005 Ford service manual
P0430 - Catalyst System Efficiency Below Threshold (Bank 2)
Description: Indicates the bank 2 catalyst system efficiency is below the acceptable threshold.
Possible Causes: See the possible causes for DTC P0420.
Diagnostic Aids: See the diagnostic aids for DTC P0420.
P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
Description: Indicates the bank 1 catalyst system efficiency is below the acceptable threshold.
Possible Causes: Use of leaded fuel.
Damaged heated oxygen sensor (HO2S).
Out of range engine coolant temperature (ECT) sensor.
High fuel pressure.
Damaged exhaust manifold.
Damaged catalytic converter.
Oil contamination.
Cylinder misfiring.
Downstream HO2S wires improperly connected.
Damaged exhaust system pipe.
Damaged muffler/tailpipe assembly.
Retarded spark timing.
Leaking fuel injector.
Diagnostic Aids: Compare HO2S upstream HO2S11 and downstream HO2S12 switch rate and amplitude. Under normal closed loop fuel conditions, high efficiency catalysts have oxygen storage which makes the switching frequency of the downstream HO2S very slow and reduces the amplitude of those switches as compared to the upstream HO2S. As catalyst efficiency deteriorates, its ability to store oxygen declines and the downstream HO2S signal begins to switch more rapidly with increase amplitude, approaching the switching rate and amplitude of the upstream HO2S. Once beyond an acceptable limit the DTC is set.
B
bedrck46
Ford
Year 2005
Model Expedition
Engine 5.4
Vehicle System ENGINE
Diagnostic Trouble Code (DTC) P0430
DTC Definition: Bank 2 Catalyst Efficiency Below Limit
65comet
Porter, IN
My dyslexia or old age has hit. I typed P0403 instead of P0430 into my code definitions. Please disregard my message for the EGR valve vacuum tee as it does not apply to that code P0430.
2005Expedition
2005Expedition
Jackson
NP, I dont think I can test this at home, I need bring to the shop, I wonder how much the shop cost to testing this code.
btw bank 2 is driver side or passenger side ? downstream O2 sensor is the one after the cat right ?
2005Expedition
2005Expedition
Jackson
im using cheap 87 gas, think I should try pump up to premium gas or non enthenol gas ?
FordandPolaris
Saint Cloud, MN
Premium will make no difference. It is just more resistant to compression ignition and has no benefit in a motor with 9:1 compression. Non-ethanol might help but really the only way to make an o2 code go away is to do a new sensor
Sent from the Pocket Computer
2005Expedition
2005Expedition
Jackson
so you think my cat is not clog ? its my o2 sensor ? which sensor should I replace ?
FordandPolaris
Saint Cloud, MN
Sorry I misread the posts and thought we were looking for the p0403 code now. Does the truck feel underpowered at all? That is a good sign that one is clogged. Otherwise my guess is still the downstream sensor.
I have read from some smart people that the downstream sensor is not imperative to tuning the motor, so it shouldn't affect fuel mileage or anything like that. If you see a drop in performance or mileage, then look at the cats first.
B
bedrck46
I would get under the expy and inspect the wiring to make sure it isn't damaged. If it is ok then replace the O2 sensor, have the codes cleared and see if they reappear
also inspect the connector for any signs of corrosion etc
2005Expedition
2005Expedition
Jackson
Hi, the truck run smooth, I just got this truck last week, so I havent note any drop in gas miles, mabe next fill up, I can tell.
2005Expedition
2005Expedition
Jackson
are you still getting the CEL and codes?
yes I do, it stay there all time, but I dint note any decrease performing, it still run smooth. But in a week or 2 I will take it to the shop to do complete test, to see which exactly the problem is.
FordandPolaris
Saint Cloud, MN
Track your fuel economy over the next tank. You Are shooting for 10-12 or higher. Any lower and a restriction in the system is possible. In my personal experience though, o2 sensors tend to go out way before the cats plug up.
2005Expedition
2005Expedition
Jackson
Hi other day I was under the truck, the driver side o2 sensor was tiny loose, so I snap it back on, I clear the code yesterday, drov 20 miles and the code havent come back yet, the car still drive smooth, I will track the gas miles.
B
bedrck46
amazing what can happen with loose wires you may have solved the problem keep the forum updated it helps others also
2005Expedition
2005Expedition
Jackson
I hope it just loose wire problem, usually how long for the computer to detect the bad o2 sensor ? its been 2 day and still no check engine light.
