Electrical issue no light, radio always on, and auto headlight not working
C
Crazy_moh
MN
I noticed that the radio will trun off after 5min or so from turing off the car.
Bedrck47
Elizebethtown, PA
Key in OFF position.
Operate the interior lamps by opening and closing the doors.
Do the interior lamps illuminate?
Bedrck47
Elizebethtown, PA
The interior lamps are inoperative
Instrument cluster module.
Vehicle security module
Go To Pinpoint Test A .
That was pinpoint Test A1
Now for test A2
A2 CHECK INTERIOR LAMP OPERATION AT THE HEADLAMP SWITCH
Operate the interior lamps by turning the interior lamp switch on.
Do any interior lamps illuminate?
Yes
CARRY OUT no communication test with suspect module. REFER to Section 413-01 for the instrument cluster module or Section 419-10 for the vehicle security module.
No
GO to A3 .
C
Crazy_moh
MN
Now for test A2
Yes
No
GO to A3 .
Yes the light will turn on from the switch.
when you have the engine running is the Service Engine light on??
No lights
Bedrck47
Elizebethtown, PA
before we get into the next test/s
With the engine off and the key still in the Ign switch does the chime work when you open the doors
Also see if the chimes work when the key is removed but your headlight are on and you open a door
dbovine
Sault Ste. Marie, ON
Im following this as well, my radio wont shut off and my interior lights dont turn on when the door is opened, no key chime or lights left on chime, no door ajar warning. From other reading I thought it was the door switch, I havent replaced mine yet but this seems to be more indepth testing
Dohc-bird
N/W Indiana
Hey take the drivers side sill plate off and get to the wires that run in there
Find urself 3 purple wires that run into a union going towards the front of the truck
The union will just look like heat shrink .
Now when u find it you'll have 3 wires going towards the rear of the truck and at the union 1 running towards the front .
In the union the wires might be corroded
I had some of the same symptoms and that's what I found .
Repaired that and everything works as it should now
Good luck
Bedrck47
Elizebethtown, PA
UPDATE
The OP sent me a e-mail this morning and informed me that,
"It was the wires I found cut them and fix them and it works like it should"
C
Crazy_moh
MN
Good luck
Yes, the problem was the purple wires. Thank you so much!
AcesOverEights
MN
Bringing this back from the dead.
Crazy_moh, DOHC-Bird, anyone else
Were these wires under the metal guard thats under the drivers sill plate? In the wire loom underneath? If so, I assume you had to crack open the loom.
Or were they in front of the metal guard behind the drivers kick panel?
I have the exact same sypmtoms, Im just trying to pinpoint the same purple wires so I can check mine.
Bedrck47
Elizebethtown, PA
this is where you want to look the wire are in the wiring loom under the sill plate I do have pictures of what you would be looking for and will post them when I can find them again
Bedrck47
Elizebethtown, PA
Pictures 1 thru 4
