My 6 month spark plug replacement
CertusExpo
Customizing trucks since I was 7 with my Legos
Fort Worth, TX
I only got to pull 1, 2, 5 & 6 but again, #5 was under a layer of moisture and rust was everywhere in the spark plug hole.
#1 and 2 had corrosion on the hex with a bit a moisture #2.
#5
Imgur: The most awesome images on the Internet
#2
Any ideas about all the moisture and corrosion? Those plugs are six months old.
ManUpOrShutUp
If it was just on the hex and the portion just below it, I would say it's likely just environment (ocean air, northern winters, etc.). With that amount of moisture/corrosion down in the spark plug wells though I would be looking at the head gasket, manifold, and block itself. Sorry if I missed this in any previous threads, but any other symptoms of a larger problem?
CertusExpo
CertusExpo
Fort Worth, TX
That is all feasible but I'm in Dallas/FtWorth so the environmental issues shouldn't be a variable.
I will explore the gasket/crack option (unfortunately).
