Body Lift is here!!!! Now I have to think about tire size!!!
dgray69
upstate ny
tracked my body lift, its not far, should be here tomarrow, so this comeing weekend i will attack that, and figure out new bumper placement, should be fun doing with no help,
Bart Man
New Jersey
Sometimes your better off with out the help, that way you cant blame anybody when something goes wrong! and also you can take all the credit when people ask who did the work! ;)
dgray69
upstate ny
i was all happy that my body lift would be here today, damn i forgot it was one of them worthless holidays unless you work for the goverment, in a bank, or ups, grrrr now im bumming, and to boot got my a$$ draged in to working over the weekend, so now i dont know how soon lifts going in, nooooottttt happyyyy
dgray69
upstate ny
oh ya and lane, good choice the hankooks look way more rugged, and are by far a better tire, the commanders are more of a street towing radial tire, stock look, and would suck any where but the road, and they do not hold up well. I use to sell them when i had my shop open, needless to say after a hand full of complaints, and dealing with warrenty issues, we stopped carrying them, many of them were comeing back with belt problems, and just bad wear patterns, generlaly i would say the issue was with the auto they were on being out of alignment, but that wasnt the case more times than not
dgray69
upstate ny
well after a screwed up weekend at work being up 52 hrs straight, i am now home with body lift in hand, 2 more pots of coffee, and im off to garage, wow, the instructions are not put together well, now i know why they dont recomend doing it yourself, you need some one to translate while you turn wrenches, should be fun, now all i need is a few extra hands, whos up for it????? any one???
dgray69
upstate ny
dig cam in hand, i think i might also do a video, i looked all over for one, nothing, so ill make one and hilight all the possible issues with the job, i wont post video but will e mail to those who want to see it, or are thinking of doing this on there own, think while im at it i may pull the carpet rino line floor, and put drain plugs in,
dgray69
upstate ny
,before concidering to do a body lift dont ask your self how hard can this be, grrrrr got battery disconected, alls good, pulled air bag fuze, yup if you dont poppy it goes when you pull the bumpers, removed all plastic sills kick plates, time to remove center seats, hmm just 8 simple bolts, yeah right 45 minutes later got the 3rd row seat out, time to work on 2/3 seat, glad i own stock in rust buster, bolts are rusted solid to floor boards, let yas know more in a bit NOTE TO SELF buy beer and pizza, make freinds, k front bumpers ready to come off, if you are planning this on your own, look very closely at lower radiator cross support, not looking good on mine, might have to replace entire front clip, no more when bumper if off, but it looks rough,, i will continue to edit this post through the project, so be sure to back up to this post, al set wires and hoses all diconnected from frame rail, bumpers off, now to loosen bolts, all going well so far i am 3 hrs into this project, could have use a hand with bumpers, but i held them up with bungies so they would not fall while removeing the bolts, k this isnt going so well now, can not break these bolts, the bushings the screw into are needed for reassembaly, hmmm think its time for a beer, and let the pb blaster do its job,. hmmmm building an orr road expedition is better than just buying a jeep why??????? And the hell begins, first broken bolt, right behind passenger seat, got less than half turn out and bolt broke, just added more time to this job, now i need to drill it out, rethread it, not good, and limited to my tools here right now, removeing the actual 10 body bolt is turning out to be worst part of the job, NY winters have put a real bad toll on this truck, having alot of problems getting these bolts out they have rusted so bad they are flared out on end threads, lane you had right idea takeing your some where, all went good till i got to this step. k need a set of torches and dont have any, this went real bad fast, the 10 main bolts that hold the body down are so rusted up from ny winters that im at a stand still ive sprayed, and sprayed with pb blaster, and im getting nowhere, whos got a set of torches they will bring me?????? k total of 7 hrs into the project alone, all went well till it was time to remove body bolts, ran in to problems, (breaking, and twistint the lower bushings, i have called it a night, i will continue in am, goes to show what northern winters will do in a hurry, will post pics soon, after breaking 2 bolts, 2 swivel extentions, and every knuckle on both hands im ready throw my hands up,things started out so well, im half way dont, will continue in am, all for 3 inches, this is what ive gained 12 hrs of hell and a 1500.)) dollor credit bill, went and bought new torches, and a new hobart welder, so if any one needs mods done let me know. i need to pay this credit card off, not so lol
walnuts4x4
Watertown, NY
you sure you need to re-use the threads in the bushings?? last few body lifts I did you had to drill the treads out and then use nuts and bolts that came with kit.... I'm in class right now start of spring symester... but i'll check back through out the day
and all the lift kits I've done or helped with ,the hardest part is always getting the old bolts out... so your almost at the half way point LOL
dgray69
upstate ny
yeah the lower bushings are what the new bolts thread in to, no way around unless i go buy washers and nuts, drill them out and do it that way, but it should be bolted to lower bushings, heres the thing! if you dont have freind or family you can count on dont do this at home and think you can do it, im now into about 14 hrs a new hobart welder, and a compleate set of torches, (over 1400$) this is turning into a night mare,, and cant even drive it to lacal shop, but hey i have a bew set of torches and a brand new hobart mig welder im happy
dgray69
upstate ny
some project pics
dgray69
upstate ny
ya like that, walnuts wasnt kidding about 3 seasons of winter, I give a lot of credit to him for keeping a daily driver as a show truck, weather here is crazy, and the salt they put down is worse, thing is it is only ont the front clip, therest of the truck is solid, bolts rusted up but frame and body solid
walnuts4x4
Watertown, NY
a lot of work keeping this daily driver looking nice.... but that has meant ALOT of trips to car wash and about 8-10 cans of undercoating everything underneath... so far its holding up great just need to redo the bottom of the inside doors ... peeled a little last time spraying it... but soon as spring the entire truck gonna get a bath then off to the body shop for professional buff and to paint roll pan and hood scoops... it will look pretty again soon I should post some pics of its current salty look LOL gotta love NNY
Lane24
Lane24
technical advisor
Alberta , Canada
Thanks for posting all these pics, and info as you go along dgray. It will help alot of people who want to do the same thing. Now I know I am glad I just paid my auto accessories shop $700 to do mine. Seems worth it now. But keep going, looks like you are doing a good job!!!!
dgray69
upstate ny
Lane you made a wise choice, it started out alright till i got to the the bolts and bushing, and the front end has me worried, new york winters have killed this truck, i will be taking more pic, and guys i do not recomend doing this on your own, ive done body lifts in the past on the trucks, sad part is most my freinds are club members and live to far away to travel here through the week, so now my dd is sitting half done in the shop hope i get it done today but doubt i will,need to figure out how i can be in truck and under it at at same time
dgray69
upstate ny
well its official, wife put me in dog house, this expy is going to lead to my divorce. wife is livid, especially over the torch and welder, now if it was a jeep she would understand, but she hasnt figured out the expedition thing yet, well any way almost done, need to do 2 front body mounts and install bumpers
Lane24
Lane24
technical advisor
Alberta , Canada
We are all pulling for you man!!! Too bad it's giving you so much troubles. It will be worth it in the end. Can't wait to see some finished pics.
