What rear axle do I got
whitelightning99
Pa
Here's the tag I unbolted off the rear the other day.if anyone could tell me what rear I got AND ratio it is that be nice .need to order the oil seals, bearings seem nice and tight still YES I know I should change both side bearings to while an at it.just don't have the money later down the road I will do them. like I said no play or movement in the axle shafts though no grinding or anything like that either.
whitelightning99
whitelightning99
Pa
Thank you, after i posted i found the info on google.Did the ever come posi ?
98eb5.4
s. ontario
early 9.75 axles had 8.8 sized axle shafts, not sure exactly when they went bigger
ExplorerTom
The solid rear was 8.8.
There were 2 solid rear axles. 8.8 and 9.75. The 8.8 is a 31 spline axle shaft. The 9.75 is a 34 spline axle shaft. Looks like the 9.75 axles are actually slightly smaller in diameter at the bearing journal (1.620" vs 1.705").
