Show your Lifted 3rd Gens
Gruz7
North Smithfield, RI
About ready to pull the trigger on a 3/2 spacer lift. Plan is to run 35/12.5s with probably 1/2" less back spacing on the wheels kicking the tires out 1/2" more on all 4 corners. Don't want them to stick out too far but I figure ill help with the rub. Are you guys changing the stock back spacing on the wheels? Also does a 35" tire fit under the back where the spare is?
Never tried it myself and I also have a second gen but I'm gonna say your gonna have issues trying to get the 35" in the factory space location... my guess...
And I don't have stock backspacing at all think I have like -6mm offset and maybe it was 4.5" backspacing? Not quite sure but mine poke out of the fenders quite a bit I'd say about 1.5" or maybe 2" in the front I've never measured and maybe a half inch less in the back
JakeEL
Forgot to add this is for a 2015 expedition El. The spacer kit says it'll clear 35/12.5, I guess that depends on your wheel offset as to how much you have to trim. Gotta get it right the first time rims and tires aren't cheap!
Gruz7
Yeah with OEM offset and backspacing there shouldn't be much of an issue... but I would say anything with more offset will require slights trimming to the front bumper/fender liners/etc.
eric3
florida
Gruz7
Maybe it's the angle, but it looks like you had to trim more on the driver side than passenger side in front of the wheel? Looks awesome though!
I think to too pic was before he trimmed and the bottom pic was after
sixsix
Louisiana
2015 EL here...plan on doing the 3/2 ready lift but not right away. I want to get the wheels/tire combo right first. So the wheel I'm looking at is 20x9 and comes in either a 18 or 0 offset...which would be the better one to go with? I'm thinking the 18? And I'm thinking of pairing that with a 295/55/20 but not fully positive yet.
Hawaiianbasshead
Big Island HI
Anyone running 3.5/2 with 10" wide wheel -24 offset? What height tires if so? Most everyone here runs tires sticking out. Love the look and found a set of rims cheap new. Everything is over priced in HI... Thanks in advance!
Hawaiianbasshead
Big Island HI
Finally pulled the trigger. 3/2 ready lift on 18" method wheels with 35/12.5/r18 bfg ko2s and full size spare. Minor fender/running board trimming.View attachment 18464 View attachment 18465 View attachment 18466 I like the way it rides more now than before.
What offset did you settle on? And those are 9" wide? looks like a +18mm if so... I had 20x9 +18mm on my old Titan and had a similar look not way outside the fenders more tucked in.
JakeEL
Rim size- 18/9, Bolt Pattern- 6/135, Offset- 18, Backspacing- 5.75"
If I could do it again I would run the 17/8.5 cheaper tires and cheaper rims.
Adieu
SoCal
Whats the UNlifted fender to center of wheel hub measurement, stock? I know mines got some lift, but cant tell how much
bjtj737
Here is my 2008 Eddie Bauer EL. Went with the Rancho Loaded kit because I wanted more travel, not just a spacer kit. It needed all new everything anyways with 120,000 miles. Before and After..
Also got 2 new Exhaust Manifolds done... if you are in Seattle area and need this work done go to Dan Fast in Bellevue. Great exhaust shop.
Moderator
People(Including Ready Lift) keep saying you can fit a 35 with the 3/2 Lift. You cannot if you have the Electric Running Boards. A True 33, Skinnier the better helps. Width of the tire, not just height matters.
Adieu
SoCal
Slamming is an artform... a dubious one, lol
Well that or pure masochism
There must be a special circle of hell somewhere where the tormented souls spend eternity trying to make aftermarket suspensions and aftermarket wheels and new tires sizes all fit together in a way that works
...and perhaps a separate one where theyre then forced to drive the darn things
