How to lift 07-up Expys with rear air strut suspension
Miekk
Madison Lake, MN
I wanted to level out the rake on my 08 KR. I ordered the 2" (1.175" thick aluminum) spacer kit from ebay (came from summit)
After the install it was plain to see that the new front height was too much in perspective to the rear.
Not listening to the "can't be done" crowd, I did one of the easiest suspension modifications I've ever done.
I've made adjustable ride height links that effectively fool the sensors into thinking the truck is too low. I'm currently running at 1 3/4-1 7/8" lift in back with no issues. Any more than 2" and a guy "could" add a thin spacer to the top of the air strut so it operates in it's factory designed position. At 2" lift the strut is only expanded out 1".
I've upgraded these links to stainless and aluminum plus went to metric for more precise adjustability. They are available HERE on ebay.
Quadmaniac
Ramona CA (San Diego)
Any reason these (or a different length equivalent) wouldn't work with front air springs just as well?
Miekk
Miekk
Madison Lake, MN
I haven't done any research on the front with air. Mines an 08 so I do not have front air struts.
I can make the links to whatever lengths necessary. I have no idea what changes in the link length equate to what changes in height nor what effect any of this has on the air strut and it's operation. I'm inclined to say, like the rear, you can extend them a fair amount without issue, but beyond that, a lift/strut spacer, should be added above the strut.
Kellogg
NY
I want to lift my car too. What do you think about usign some custom coil springs for this purpose? I want to use some of those from company for my ride. Maybe you guys used them before and have some thoughts
Kellogg
NY
Miekk
Miekk
Madison Lake, MN
Your car? Please be more specific... "use some of those from company"... you live in China? This thread is about a special part for lifting expeditions with air struts. Please delete your post and start a new thread or go to the general lift section..
Thanks
gixer2000
Retrofit or Bust
Massachusetts
I'm just finding this thread and wonder how this mod has held up. Did the new links have to be modified at all or a direct swap for the oem?
gixer2000
Retrofit or Bust
Massachusetts
I just realized your building these and I'm very interested in hearing more feedback on how they have worked out for anyone that tried them
Miekk
Miekk
Madison Lake, MN
Adjust these according to the directions as a place to start, take out OEM, and snap these into place. If you want more or less, adjust accordingly.
I have them set to 2" for about 3 years and 20K using them.
gixer2000
Retrofit or Bust
Massachusetts
Brilliant idea! I'll be ordering a set in the next couple days. Thanks!
gixer2000
Retrofit or Bust
Massachusetts
Do you have stock size tires on your king ranch or what are they? Got my front lift, got your rear links and getting ready for tires soon
gixer2000
Retrofit or Bust
Massachusetts
Stock 275/55-20s
Michelins
They are bran new in the pics.
Got your links and an autospring 2" lift installed today. No pics yet but these links are awesome and was able to achieve exactly what I wanted without sacrificing the comfortable ride.
Miekk
Miekk
Madison Lake, MN
Thanks! I'm glad they are working for you as well.
Pulled a 3 place trailer with 4 sleds on it yesterday so I wasn't able to place the load where I wanted. I bet I had over 700 lbs tongue weight and everything leveled out and pulled beautifully. I wonder how far a guy could go with it....
gixer2000
Retrofit or Bust
Massachusetts
So I have a question. I installed a 2" level lift in the front 1.75 thick and ended up with about 3" of lift. You said your spacers were the same but mine is really high and not sure why I got so much more. Crappy pic but it's high enough to make my wheels/tires look tiny. I'll get some day shots tomorrow after work. Any thoughts?
gixer2000
Retrofit or Bust
Massachusetts
Just noticed your spacers are 1.175 so that's the difference. They claim this gives me 2" but it's way more and has to go. Do you have a link to the ones you ordered?
Miekk
Miekk
Madison Lake, MN
No members online now.
Landsbutter
