Not turning over with key
Bedrck47
Elizebethtown, PA
Yes the solenoid can cause the fuse to blow BUT also anything else in that circuit can cause the fuse to blow also
Is it fuse #21 that is blowing? Make sure you are using a 15 amp fuse
rjdelp7
2000 XLT
NY
Are you low on coolant? You engine could be hydro-locking.
Bedrck47
Elizebethtown, PA
Had you read the OP's first post in which he stated
" I am able to start it by jumping the two bolts on the firewall with the solenoid using a pair of pliers."
You would have know that it isn't hydro-locking
rjdelp7
2000 XLT
NY
OK, but by jumping the solenoid, you are by-passing the fuse.
Bedrck47
Elizebethtown, PA
You are correct about by-passing the fuse.
The OP is trying to figure out what is blowing the fuse and its not being caused by Hydro-locking since he can stat the engine by jumping the starter contacts
rjdelp7
2000 XLT
NY
OK, Yes, but why would a 100 amp start fuse blow? I know it is rare, but a stuck injector or leaky head gasket, could just fill one cylinder enough, to pop that fuse. A DC electric motor, can take a massive amount of amps. Jumping the fuse, could discharge the battery, in no time. It is more common in diesel, equipment, like dozers or excavators .
stamp11127
Temple, Georgia
Doesn't sound like the maxi fuse is the one he is popping. Sounds more like the fuse for the control side of the starter relay circuit.
Bedrck47
Elizebethtown, PA
Take a look in the print of the starting circuit that I posted in this thread and TELL ME where you see a 100 amp start fuse
rjdelp7
2000 XLT
NY
Look man, you can't even read what you uploaded, it is too small. It is a high current/amp fuse. Why don't you just post the correct Maxi or "under hood fuse" number, if you know it. It is not helpful, posting condescending questions. Just stick to helping this guy. That is what people come for.
Bedrck47
Elizebethtown, PA
And how are you helping him? Instead of adding comments about things the aren't in the circuit. Try to comment on what is posted rather than what you think was posted
Again Where is the 100 amp fuse in the starter circuit?
The ONLY fuse that is shown in the wiring diagram is fuse #21 a 15 amp fuse located in the fuse box under the dash and if you knew how to read and understand wiring diagrams you would have seen that and also have known that there would never be a 100 ANP fuse installed in control wiring
AaronMoss72
AaronMoss72
Western NC
Good Morning Everyone! I think i may have narrowed it down to something in the steering column... I went through 5 fuses over the weekend (15amp) yesterday I blew 3 just trying to turn it over. To access the fuses better I raised the tilt to top position and it started. Multiple times without blowing the fuse. I haven't moved the steering back down and it started this morning. I'm hoping there is just some type of loose connection. Thanks to everyone for your replies and hopefully i can figure out whats in the column. Opinions anyone?
Best,
Aaron
AaronMoss72
AaronMoss72
Western NC
Another week, another headache :) Replaced solenoid still blowing the fuse. I'm believe it has to be a loos wire or something grounding out. It will start fine some days and if i stay on nice roads it seems to start again and again. If i get into any potholes, gravel, etc. it blows the fuse. Going to get under it this weekend and try and follow the wires from the starter up and from the firewall to the switch to see if there is something that may be causing it. I REALLY appreciate everyone's input and if anyone out there has other suggestions please advise! Another question... The fuse that is blowing in the manual refers to it "Starter relay, Junction Box #20" could it be something in another box that is causing this, and anyone know what the #20 is for?
Best,
Aaron
Bedrck47
Elizebethtown, PA
The fuse that is blowing in the manual refers to it "Starter relay said:
What that is referring to is it is fuse #21 which is located in the fuse box under the dash The #20 refers to fuse #20 which is located in the fuse box under the hood That is a 50 amp fuse which is the feed for fuse 21 and a few other circuits.
Try to think of it as your house wiring You have a 100amp main but you have smaller 15 amp circuits that protect different outlets
If your just blowing the 15 amp fuse #21 then your problem is located somewhere in that circuit and that is the print that was posted earlier BUT if the 50amp fuse #20 is blowing then you have a bigger problem, I doubt that the 50amp fuse is blowing
I believe that your problem is the 15 amp fuse and the wiring in that circuit.
If you look at the wiring you will see that it comes from the ign switch then thru fuse #21 then to the digital trans range sensor and then to the starter motor relay
Which meant the wires go from the steering column to the fuse box then under the carpet and thru the floor to the range sensor and come back thru the floor and then go thru the firewall to the starter relay.
Any of those areas could be where the problem is located
stamp11127
Temple, Georgia
You narrowed down the problem with the harness or ignition switch in the steering column then proceeded to replace the solenoid on the firewall. Take a look at the diagram Bedrck47 provided and chase the wiring in the column looking for an exposed or cut wire.
