So I'd like to document my experience thus far with ReadyLift's SST 3/2 lift kit for my 2016 EL Platinum 4x4. Great customer service when I ordered over the phone (part # 69-2070).
Arrived in 3 days after order was placed and here is what I got: a front spacer for an F150 and rear spacers for an expedition. Notice that the picture on the box is different shaped spacer than what is in the box?? Wtf. Called them to verify and they said some kits use same parts from other kits which is fine. I have the correct parts.
Now to the instructions and where I ran into issues: somewhere between 2011 and now, the front lower strut mounts changed from a single bolt that slid horizontally through a piece of metal on the LCA to two 2-3" bolts that now slide vertically through the LCA itself. The instructions have not been updated since 2011 for our expeditions, folks. So I removed the strut assembly, installed the spacer, and when I went to reinstall, the strut assembly would not fit back in because the two bolts would not clear the LCA and reseat themselves into their holes. After trying to find a spring compressor (with no luck bc the ones at auto stores won't fit around the size springs we have) I have up and reinstalled factory setup.
After further research, I found that the f150 instructions HAVE been updated for more years up to 2016 and that not only do the two bolts have to be hammered out to clear the LCA and reused but our EPAS also has to be disconnected or risk damaging the electronics inside it and burning it up.
So sometime next week, I will be retrying the install and will update with any further issues found and results. Thanks for letting me go on this rant
