scoot0073
Georgia
Pre-runner flares would be very sweet. I would also like to do something like that in the future possibly. But yes the light mounted directly where the fairing goes gives me a lot of light output I used rigid industries mounts to put it up there
Did u drill through the roof for the wiring or is running along side the door jam ?
Gruz7
North Smithfield, RI
I ran it behind the weatherstripping and I drilled through the pinch weld then re-sealed it with 3M weatherstrip glue. Worked perfectly haven't had a leak ever.
scoot0073
Georgia
Mine is a 52 curved not sure how it would look mounted there but I think I'm going to try it this weekend.
The only issue I have with mine is at night when it's on the dash glares on the windshield so bad that I can't drive it safely..
Gruz7
Yeah I've heard of that too that's why I stayed away from windshield mount, but mine is a 40" or 42" can't remember, and it fit perfectly inside the bars of the rack
EliteFord
tulsa
same years may fit
Sent from my SAMSUNG-SM-G935A using Tapatalk
it's possible, but the f150 painted section is slightly different, so not sure if the lower part would bolt right up. anyone know of a lower valance out there which bolts right on?
acolic
Hamilton Ontario Canada
How did you run the wires for the top lights?
Habbibie
Is it Christmas yet?
Chicago
I'm on my way to go fishing with couple of the guys, taking the expedition since it's been sitting for two weeks looking like a driveway ornament.
bearss07
NC
Noticed a few spots in the driveway where it's parked. Gotunder there and see this. It looks all reddish, only on the trans, not the oil pan. Also coming from what looks to be where the shifter goes on. Is that a common leak point. Going to replace the trans pan gasket before long, have to get my Jeep back on the road first though.
ExpeditionAndy
Fort Wayne, Indiana
I think you will want to post this in the proper forum so you can get some answers. What year is it?
jeff kushner
North of Annapolis
I finally swapped out my bad headlight LED bulb yesterday....I replaced both as a set. The damn things had the retaining tit on the wrong side.....these are the bulbs....it would have been nice to have done these BEFORE the road trip....aw well, at least it was nice driving in this morning!
jeff
sjwelds
Kansas
Couple days ago. Fixed a sticky rear wiper. Fortunately everything came apart nicely. Cleaned it up with some sandpaper and put it back together with sil-glyde. Works great now.
