Strange alternator issues
kyle_in_rure
TN
Hello all,
A little over two years ago the replaced the alternator on my 97 4.6 Expy because it was not charging 90% of the time. It left me stranded after about a week of having issues with keeping the battery charged.
Now I am having a strange problem. When i first started it up in the morning to go to work (in the dark), I noticed the headlights are dim, wipers slow, etc. it was like this for the first 20 minutes of the drive then magically started acting normal again. It has done this every day for the past week. I checked the voltage at the battery posts when I was noticing the dim lights and it was a solid 12.1 volts (not high enough, right?) and when it starts charging again it is around 14.1 volts. The trouble is I’m not sure where to start looking first. Is this an alternator issue or some kind of regulator issue?
Also I noticed the battery light in the instrument cluster is burned out, so if it should be coming on it obviously isn’t.
Thanks!
stamp11127
Temple, Georgia
Check the plug that connects to the alternator and also check the output wire terminal where it bolts onto the stud.
Check voltage between the output stud and alternator case then next time you are having the issue. Charging voltage normally runs between 13.5 - 14.5 volts. If it isn't charging with that test the field coil isn't being energized. That can be from a faulty plug, coil or voltage regulator.
K
kyle_in_rure
TN
Hi stamp,
Before I got the chance to do any investigating, it kicked back on today while driving and was making a loud whining noise. This makes me think it’s on its way out... what do you think?
K
kyle_in_rure
TN
Also, strangely enough, the battery light is illuminating again when I turn the key to run but don’t start it. Seems weird to me that it appeared burned out before....
K
kyle_in_rure
TN
Yeah I agree. Could the battery light acting up have anything to do with the alternator itself?
I was reading on some sites where the battery light sometimes helps form the charging circuit and the alternator won’t charge without it. Strange
stamp11127
Temple, Georgia
Not to my knowledge. It provides a current path when the alternator isn't charging. That passes current through the bulb and illuminates it.
1955moose
On my Lincoln mark 7 that was the case. It has to have a functioning bulb and circuit for the charging to work. If it were me I'd clean all connections involving charging. Like stamp said, its most likely either the regulator inside alternator, or alternator itself going south. But eliminate all your connections first. If you can find one, new alternators work better than remans. They rarely use quality diodes on most remanufactured units. Let us know what you do
Big Brian
Farmington Hills Mi
I dont know what kind of alternator you got but I dont mess around with rebuilt or reman units.
Only new for me. May cost a little more upfront but worth it in the long run.
stamp11127
Temple, Georgia
OK, got the book out. Some alternators do not have residual magnetism to start the process of generating electricity. These alternators will send current to the field coil through the light bulb and create the magnetic field needed to start the current flow when the ignition key is first turned on. After it is running it uses some of the electricity generated to power the coil and extinguish the light.
So if the bulb burns out, the coil doesn't get energized initially and the result is no output.
K
kyle_in_rure
TN
Interesting. I wonder if mine does the same thing.
If so I wonder if it is actually the alternator and not some connection issue, although the whining noise makes me suspect otherwise
1955moose
The whining could be a bushing/bearing going out, but that's a whole different issue. As we've stated in earlier posts, disconnect your belt, spin each pulley. The one that's failing will sound like an old roller skate.
theoldwizard1
SE MI
Whining is either a
When a regulator detects a low battery and applies full voltage to the field the alternator may also whine.
The regulator controls the operation of the battery/charging light.
Either way, it sounds like you will be buying a new alternator ! RockAuto has NEW (not rebuilt) Bosch alternators with a lifetime warranty for about $135 plus shipping !
knewblewkorvett
Iowa
You might have both alternator and battery problems. With the vehicle off you should have at least 12.5 volts and when vehicle is on it should read over 14 volts (both measured at the battery). You can go to a place like AutoZone or Advance Auto and they will test both your battery and alternator for free.
theoldwizard1
SE MI
It will NOT always read > 14V with the engine running. The minimum charging voltage (at the battery) is 13.2V.
1955moose
These SUV's absolutely need a sound battery to function. A battery with one questionable cell, can wreak all kinds of havoc. 13.2 volts is not quite enough. If you start out with 12.6 volts, the voltage point a stable, good battery should be at, charging should jump up to at least 13.8 to 14.5 volts. Now if you turn on all accessories, a/c, lights, etc, it may drop some, but not below 13.6 volts. The fact that your low charging light all of a sudden started working, tells me you got a cruddy connection somewhere. Time to play electrical detective, and find out why?
K
kyle_in_rure
TN
Sorry for the delay been a crazy week. I took the old one out on Friday and it was making a squeaking/grinding noise when spun it so I suspect it was on its way out. I replaced it and she is charging like normal again. It holds around 14.3 when unloaded and about 13.6 with a bunch of stuff on.
The battery light on the dash still doesn’t turn on sometimes when I turn the ignition without starting it, but this is not affecting the charging so I don’t think it is much of an issue.
1955moose
When you get some time, you might want to swap out that bulb, clean connection. You want to know right away if your charging isn't up to *****. Problems always seem to rear their ugly heads, during a rain/snowstorm. If the light works, you know it's time to head home.
K
kyle_in_rure
TN
Moose,
I plan on doing this soon when I get some time. My current instrument cluster came from the junk yard as I broke the other one trying to fix the odometer.....
I had to change most of the bulbs in the “new cluster” but it’s possible I missed the battery bulb....
No members online now.
jtebbe0529
