Vibration during constant speed
Adieu
SoCal
i am curious how we can tell that the shocks look to be shot from the video... I would think that, unless you are driving or standing next to it, there is no definitive way you can tell the shocks are kind of shot... i just think it's the road and arm moving due to filming... i could be way off base and sorry... just seemed a stretch...
The rhythmic bounce recoil bounceback and sway....shocks are short for "shock absorbers" you know
I dunno its how i was told to look for worn out shocks by some limo/livery suv guys i know...
Doug Kuhlman
Indianapolis, IN
I believe that your transmission needs mercon V (not mercon LV) Atleast that's what is specified for my '04. I've read that they aren't compatible! You might want to double check that you put the right stuff in there!
M
Mike1988
Mooresville, NC
I did call the Ford Dealer. They said Mercon LV is the right juice for my 2007. As I heard before, Mercon SP is also ok.
Mr Pham
Houston
I just picked up an 07 EL. Having same issues. After a quick search it seems like a common problem. No real answer on how to solve. Some people change the fluid in the transmission some people change the torque convertor.
Saltydog
I had an 06 which shuttered during shifts. I read on a form somewhere that a check ball in the transmission would cause it. Ordered parts from ford about $15 for 7 BB's garage changed it. The check ball had split into. Worked fine afree the repair.
ExpeditionAndy
Fort Wayne, Indiana
Saltydog, welcome to the forum!
USMCBuckWild
Camp LeJeune, NC
Welcome to the forum.
Filter was probably very dirty and restricting flow through the trans, causing excessive heat and essentially evaporating some of the fluid.
You lucked out. Very easily could have burned up/grenaded the entire trans. Good oem filter and good fluid, NO ADDITIVES!!!
I would drive it for a week and change the fluid again. When dropping the pan and changing the fluid you actually drain out a little more than 1/3 of the fluid. You have done it twice now, each time diluting the existing dirty fluid with good clean fluid. One more fluid change should keep you going for quite a long time. You would be surprised as to how dirty that new filter is already especially if the old one was that dirty.
